Question about Sunbeam Humidifiers
Changing an E filter on my sunbeam humidifier model SCM7808 I have no clue where it goes. PLZ HELP!
    New Friend:
I also want to know. It looks like any sone of 3 places. The manual has no picture. It advised taking the filter out when in storage. Ha, I forget where it goes. The got me good. No more sum beam for me.
Posted on Jan 06, 2016
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: sunbeam ultrasonic humidifier model 696-12
I want to order this rubber gasket
Posted on Feb 24, 2009
6ylucy
  • 742 Answers
SOURCE: I need to know how to clean the base of my humidifier.
ask at http://manualfox.com/link/sunbeam.htm
They will find it for you.
Posted on Jan 03, 2010
SOURCE: I have a Sunbeam humidifier
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Posted on Dec 07, 2010
SOURCE: How do I change the
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Posted on Dec 12, 2010
I dont know how to add water to a sunbeam humidifier model#scm808
Hallo
Can you not find the owner manual?
The best I can do is advice you to go online and find MANUALSONLINE.COM. There look for the brand name "sunbeam" then the product humidifier.
In the one in this house you lift and take the filter out and water in.
Good luck
Kolbrun
Apr 23, 2012 | Sunbeam Humidifiers
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
Nov 19, 2010 | Sunbeam (0013871361) Humidifier
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
outlet.
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
Sunbeam humidifier model 2422 will not reset low tank
I have a similar issue and this is a no filter warm mist humidifier. I just need to know how to reset it, but can't without manual that I don't have!
Mar 06, 2010 | Sunbeam Humidifiers
Sunbeam ultrasonic cool mist humidifer model 700
The Problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck.
Feb 17, 2008 | Sunbeam Ultrasonic Humidifier
Humidifiers Logo
600 people viewed this question
Top Sunbeam Humidifiers Experts
Oloyede Monsuru
mike
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
