Question about Zynga Farmville
Animal workshop will not complete, so can do final step for grand prize, in Mistletoe lane please help
Help please at wits end!!! i have completedf EVERYTHING in my Mistletoe Land big quest for grand prize ecxcept animal workshop no matter how many "animal spirits " I have or how many animals i make it show NO progresss I have been at this for weeks what gives. really want the prizes I worked so hard for.
What are the poisonous plants I cant give my rabbits?
here is the list of dangerous plants: anemone,azalea, bittersweet, bryony, caladium, cyclamen, columbine, dog mercury,figwort, deadly nightshade, woody nightshade, poppies, ragwort, buttercups,daffodils, bluebells, foxglove, hemlock, spurges, kingcup, marsh marigold,monkshood, meadow saffron, mistletoe, St. Johns wort, Leyland cypress, foolsparsley and hellebore.
May 15, 2012 | Pets - Others
1996 jeep cherokee laredo front differential is broke what do i do to fix and how hard is it. should i replace the whole axle unit or just the differential
If you can get hold of the complete front diff housing,including all the brakes etc,it is a lot easier to do the change.On the other hand,if you have a good workshop and know the steps to take,replacing just the diff centre is a bit cheaper.By a good workshop I mean,hoist,air tools good lighting etc.Both jobs require approx.3hours and a good helper makes the job a lot easier.Without a good workshop I would go with replacing the entire unit.Make sure the brakes are in good condition clean and all the air bled out of the system.Replace the diff oil using l/s diff oil.Hope this helps
Jan 20, 2010 | 1998 Jeep Grand Cherokee
Need to remove the alternator
Remove windshield wiper blades (mark the arm and stud to put back exact). The next two steps you might have to lower/raise the hood. Remove cover just below the windshield(each end has a phillips screw turn 90 degrees so arrow points toward center of van). Remove the 4 metal braces. Remove windshield wiper motor/linkage assembly(the whole tray comes out). Remove drive belt. Disconnect negative side of the battery. Remove alternator horizontal mounting bracket. Loosen vertical bracket bolts to get to electrical connectors. Finish removing bolts and alternator.
Jul 18, 2009 | 1994 Plymouth Grand Voyager
Zynga Farmville Logo
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Corne Viljoen
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
