Question about Mitsubishi WS-65819 TV
Vertical Lines on my Mitsubishi WS-65819
There are vertical lines that appear intermittently on the screen of my Mitsubishi WS-65819. The TV will work fine and suddenly the screen will fill up with vertical lines spaced about an inch apart all the way across the screen. The problem started about a week ago, it seems to happen more often now. The picture is still visible behind the lines. It happens when the input is switched to cable TV and also when the input is switched to DVD to watch movies. I've tried changing out DVD players and still have the same problem. I've also tried removing the cable box from the system. So far nothing has helped. The lines keep coming back. Any suggestions?
  • Geo Clay Jul 24, 2007
    Regarding the certical lines that appear on the screen - the lines disappear when I turn to an HD channel. Everything in HD works fine. Maybe this info will help to correctly diagnose the problem.
    President:
  • 3,130 Answers
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Posted on Jul 11, 2007
  • Larry  Dillon
    Larry Dillon Jul 24, 2007
    The DM board is most likely going bad then. Or the Capacitors inside the DM board is going bad.
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Tv vertical lines
Remove back .... lightly tap modules with plastic screwdriver
handle to isolate where bad connection is.....pull module or
chassis...solder,then repeat until problem solved......T.
Dec 24, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Intermittent vertical lines
PANASONIC PV-C2540 Intermittant PROBLEM, picure is reduced to left to right vertical line. SEEMS TO WORK FINE WHEN SET HEATS UP?
Dec 22, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
65 INCH PROJECTION SCREEN IS SUPER BRIGHT
super bright is due to failure in video section. 1 video supply might be absent. 2 g2 voltage mighi be high gue to some part defective at ground side. 3 chroma or jungle ic not getting supply or defective. 4 luminance section defective. BUT AS you are also saying that it came once after hitting on top so there is also possibility of loose contact also. good luck.
Sep 18, 2007 | Mitsubishi WS-65819 TV
Vertical lines in picture
If your satellite is in the component jack and does not have the lines, you have a bad doubler or 2HD board. These boards are located in the metal container on the left side of the tv (left as in when you are looking at the back of the tv).
Mar 31, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65819 TV Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
