Question about Refrigerators
Liebherr fridge kt1730 not cooling. Is there an easy way to establish if the problem is the thermostat or compressor?
My Liebherr which is two years and nine months old has stopped cooling. Think its working slightly but isnt at all cold, even when turned up to seven. The lights on, the compressor is still whirling away, so presumed it was the thermostat. But had a chat with a local repair firm and they said it probably wasnt worth fixing as it could also be that the compressor wasnt pushing the gas round properly or that none was getting round at all and that wouldnt be worth fixing on an undercounter model. But they also were surprised that a relatively new model should have just packed up. I recognise that its probably safer just to ditch it and get a new one but on principle it seems wrong to through away something to landfill that looks like its almost working. Does anyone know of any ways to easily establish whether its the thermostat or the compressor Thanks very much for your help Catherine
  • 1462 Answers
SOURCE: Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
huuum
  • 750 Answers
SOURCE: Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Posted on Oct 14, 2008
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
  • 106 Answers
SOURCE: fridge is no longer cold
Either a bad relay on the compressor. Or a scized or locked up compresor. My co. in NJ gets $95 to replace the relay, $450. to change compressor. $25.00 just to check it out. The Dealer is always more $$
Shop around, Smaller companies, smaller price.
If your unit has a Embraco compressor it may just need a new relay. The Tecumseh compressors all went bad and now are replaced by Embraco's
Posted on Nov 11, 2009
diodeic
  • 1622 Answers
SOURCE: Fridge no longer stays cold
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout in solving the problem
Posted on Aug 15, 2010
Testimonial: "Good thorough reply! Thanks so much!"
My Liebherr Fridge / freezer has just stopped working. The light is on but there is no refrigeration, it is only about 4/5 years old. Help!
It is a technical problem more than likely but will require someone who can use a voltmeter. If the compressor is running then it is probably out of freon.
Mar 01, 2018 | Liebherr Refrigerators
Very noisy Liebherr CN4013-21 - 4 years old
Might be, the compressor is loose, now is it loose at base where it is fastened or the bearings are loose.
Dec 16, 2013 | Samsung RS2630WW Side by Side Refrigerator
The fridge is not cooling,no fan noise but light on
Make sure that the compressor is working, You will need to take the fridge out and check the compressor motor for the start up on switch on > If not check the starter/contactor which could be defective and fitted to the motor. replace if faulty. Use a clamp tester or get help to finalise on this observation. Use a multimeter for checking for the voltage to the fan also. It might be possible that some rodents could have biten off your wires while you were out. so lets hope this is possible and so take a good look inside. If not check your compressor, starter. Good day
Aug 02, 2010 | Liebherr KIU 1640 Premium Compact...
My fridge freezer is omitting cheesy smells from
Im still looking for the same problem and how to solve. Ive established it stagnant water in the drip pan at the rear. I keep cleaning it and intermitantley it comes back with water that looks like cheese curd in it........ Im going to call Liebherr as the fridge has been doing this since last year and is now getting worse but is only 2 years old.......
Feb 04, 2010 | Liebherr KES4260 Refrigerator
Our fridge and freezer seems to have turned off but the light is still on- we have a ten year old Liebherr KDVES4632, stainless steel-any tips, please?It is not blocked or obstructed at the back
Could very well be the compressor might have went bad. If nothing is running its the only thing it can be. Try turning both freezer/ refrig thermostats to their highest settings to see if compressor and evaporator fan is working.
Dec 15, 2009 | Refrigerators
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Need parts diagram for scandinova fridge LF111D to find out which
To test the stat short out the wires and see if the compressor operates and cools the fridge.
Dec 25, 2008 | Refrigerators
Sep 23, 2008 | Liebherr Refrigerators
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
