Question about Kenmore Top-Load Washing Machine 3.4 Cubic Foot
Why did it stop running?
It stopped running mid-cycle. i assume it is the fuse but prefer to research online first. i may have overloaded it. the lid button seems mechanically sound. there is no operation or sound when i pull out the dial... no matter what setting.
    Sergeant:
  • 291 Answers
Check house breaker or fuse. There is no fuse on the machine.
Posted on Jan 07, 2013
  • glennskii meyer Jan 09, 2013
    this is what it was! you are a real handyman!
  • 686 Answers
SOURCE: kenmore washer,mod# 110 26292694/wash cycle only
CHANGE THE LID SWITCH
Posted on Apr 09, 2009
vickygomar
  • 460 Answers
SOURCE: washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
Posted on May 12, 2009
  • 3 Answers
SOURCE: lid locked no power
use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Posted on Nov 22, 2007
  • 100 Answers
SOURCE: Washing machine won't drain
It sounds like you may have some bad contacts in the timer or you may have a bad lid switch which will not allow it to go into a spin during the rinse cycles or the final spin.
Posted on Oct 30, 2007
SOURCE: My Kenmore model 110-20922990 stops mid-way
the switch at the lid needs to be replaced
Posted on Sep 24, 2009
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
My old Whirlpool DU8500X stopped yesterday in mid cycle and now will do nothing. Standing water in bottom. Tried breaker reset already.
If it is a top loader, a whirlpool normally has a fuse in a cartridge holder inside the top panel. Once panel is opened, trace the power wires, and look carefully for the fuse cartridge holder. Replace it. This fuse normally protects overloading of washing so as not to damage motor.If the fuse is good, then try and bridge the door limit out for a short while to ascertain if that is the problem. Please let me know.
Oct 02, 2009 | Dishwashers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
E1 comes on during mid cycle and stops the dryer from drying
replace the compressor "compressor relay and the compressor overload" that are on the side of the compressor.
location: should be in the back on the bottom behind the panel.
if you have a circuit board they may need to be replaced as well.
May 09, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Kenmore Top-Load Washing Machine 3.4 Cubic Foot Logo
169 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
