I want connet foxpro databse to visiual basic
Please give me code to connet foxpro databse to visiual basic
    Problem Solver:
  • 20 Answers
Using a DSN-less connection to open a free table
cn.Connect = "SourceType=DBF;" _
& "SourceDB=C:\Vfp\Samples\Data;" _
& "Driver={Microsoft Visual FoxPro Driver}"
Posted on Feb 18, 2009
Is it possible to Repair DBF file?
If the file needs to be repaired, it is already damaged. To make things worse not only keeps a spare copy. And so - foxfix very powerful tool for recovery. Or a hex editor to see what is written in the tail of the file if the garbage - it cut before the "normal" data (aligned along the border post), to calculate the size and the size of the .dbf header records how many there really are, and to correct the record count in the header. Also there is a file header, which is similar to can (and should) rule in heh mode.
here you can see this topic. Here is the link to the forum
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/593-foxpro-behavior-when-opening-dbf
and even try to program DBF Recovery Kit
http://www.all-recovery-inc.com/#!/foxprorecovery
Dec 02, 2014 | Microsoft Visual FoxPro Professional...
Please give me the procedure how to import foxpro files in tally 7.2
To import data from a FoxPro database, use the Microsoft Visual FoxPro ODBC driver. To do so, follow these steps:
1) Click Start, and then click Control Panel.
2) In Control Panel, double-click Administrative Tools.
3) In the Administrative Tools window, double-click Data Sources (ODBC), and then add a new ODBC data source for your FoxPro database or tables by selecting the appropriate Visual FoxPro driver.
4) Start Access, and then open your Access database. 5) On the File menu, point to Get External Data, and then click Import. 6) In the Import dialog box, click ODBC Databases in the Files of type list. 7) In the Select Data Source dialog box, click the Visual FoxPro data source that you created in step 3, and then click OK. 8) In the Import Objects dialog box, click the tables that you want to import, and then click OK.
Jul 05, 2010 | Computers & Internet
How to install foxpro
You can install this version of Visual FoxPro from a CD-ROM or anetwork to a local hard drive. You must install Visual FoxPro on alocal drive, not a mapped drive. There is no other preparation requiredbefore installing Visual FoxPro. You must have administrator privilegesto install Visual FoxPro. It is recommended that you run withpower-user privileges to use all the provided tools effectively.
Youcan safely install or uninstall using Visual FoxPro Setup. If you areupgrading Visual FoxPro, you must first uninstall the previous versionof of the program. Though both versions of Visual FoxPro can exist onthe same computer, you cannot install the current version of VisualFoxPro in the same directory as the previous version.
If you planto publish XML Web services using Visual FoxPro, you might want to setup Internet Information Services (IIS) on a Windows 2000, Windows XP orWindows Server 2003 computer. Refer to your operating systemdocumentation for instructions on how to set up and configure IIS.
030c41d9079671d09a62d8e2c1db6973.gifNote VisualFoxPro setup no longer installs any Windows operating system ServicePacks or versions of Internet Explorer. It is highly recommended thatyou install the latest versions of these components before installingVisual FoxPro. Additionally, Visual FoxPro 9.0 is supported only onWindows 2000 Service Pack 3 or later. For details about installing thelatest Service Pack, visit the following Microsoft Web page at http://www.microsoft.com/windows2000/.
Full installation includes all Visual FoxPro program files, online help, and samples files.
To install Visual FoxPro
  1. Quit all open applications.
    030c41d9079671d09a62d8e2c1db6973.gifNote Ifyou use a virus protection program on your computer, override it orturn it off before running the Installation wizard. The Installationwizard might not run properly with virus protection turned on. Afterinstallation, be sure to restart your virus protection program.
  2. Insert the Visual FoxPro CD.
    The Visual FoxPro Setup start page appears automatically.
  3. Click Install Visual FoxPro to launch Visual FoxPro Setup.
  4. To determine if you need additional components, click Prerequisites to display any necessary components.
  5. Click Install Now! to install any new components. If Visual FoxPro Prerequisites needs to only update components, click Update Now!
  6. You might need to restart your computer. When finished, click Done.
    Visual FoxPro Setup reappears.
  7. To continue installation, click Visual FoxPro.
  8. After accepting the End User License Agreement and entering the Product Key and your name, click Continue.
    030c41d9079671d09a62d8e2c1db6973.gifNote Visual FoxPro cannot be installed on a mapped drive. You must install Visual FoxPro on a local drive. Do not attempt to use the Map Network Drive functionality in Setup.
  9. On the Options page, select the features you want to install and click Install Now! to continue.
  10. When finished, click Done to return to Visual FoxPro Setup. Click Exit to return to the Visual FoxPro Setup start page.
Ifyou uninstall Visual FoxPro while the previous version of Visual FoxProexists on your computer, certain shared registry keys used by theprevious version of Visual FoxPro are removed. You must reinstall thesecritical shared registry keys.
If you run Visual FoxPro fromthe Start menu, Visual FoxPro Setup automatically reinstalls thesekeys. If you start Visual FoxPro using other means, such as running theapplication executable directly, the setup program does not startautomatically. You should use Add/Remove Programs in the Control Paneland the following steps to reinstall the registry keys manually:
To manually reinstall Visual FoxPro 9.0 registry keys
  1. From the Start menu, click Control Panel.
  2. Click Add/Remove Programs.
  3. Click Change/Remove for Microsoft Visual FoxPro 9.0.
  4. Click Visual FoxPro and Repair/Reinstall.
Good Luck
Jun 26, 2010 | Microsoft Visual FoxPro Professional...
Difference of Visual Basic and Visual Foxpro
The reliability comes from the quality of workmanship of the systems people. The language is irrelevant except that some languages have limitations. I would consider that these two are six of one and half a dozen of the other. You must decide on who you feel is giving the best deal AND will give you the best BACKUP SERVICE.
Feb 04, 2010 | Microsoft Visual Basic Enterprise Edition...
How to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Import .dbf file format to tally 7.2 file format
Exist some tools for solving like issues, and to my mind one of them might be able to help in like situation. I found out one of them on an one soft forum - dbf recovery.
Mar 01, 2009 | Tally T2245 Matrix Printer
Web server and web browser
web server stores websites allifo and databse .
Browser read the html or xml code.then give output on page.
Example are:
web server :apache server.
Browser:mozila firefox
Jan 21, 2009 | Computers & Internet
Hanged foxpro
some file could have be corrupted or the anti-virus not giving access to some files.
Try re-installing FoxPro. If this did not resolve, please get back here.
Jan 15, 2009 | Microsoft Visual FoxPro 9.0 Professional...
Foxpro dos application exe obfuscation
you need the re-fox or fox shell
is works good
an from mexico
Jan 02, 2009 | Microsoft Visual FoxPro Professional...
Download Visula Foxpro 7/9
You cannot download Foxpro 7 either as a trial or free version.  You may be able to pick up a copy on eBay  If you are trying to get a program to work which requires Foxpro 7, you may get away with just having the runtime files.  You can download the version 7 runtimes here: http://www.alexnolan.net/runtime/
Nov 10, 2008 | Microsoft Windows Xp Home Edition Sp2...
Computers & Internet Logo
142 people viewed this question
David Payne
David Payne
