Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity Atf7000e...Does not load up water.
Frigidaire Affinity washer side loading.
1 and 1/2 year old
Everything behaves like normal except no water is loaded into machine.
I have double checked water connections and water is going into the machine. Upon start up you can hear the start up noise but when the water is supposed to load you just hear a humming noise.
  • 1 more comment
  • mythosx Feb 01, 2009
    thank you
  • Anonymous Feb 14, 2009
    My washer won't load the water all I hear is humming and then it turns off.
  • Jack Iaria
    Jack Iaria May 11, 2010
    How old is your washer?
  • 640 Answers
Clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
Posted on Jan 31, 2009
    Scholar:
  • 48 Answers
Make sure the drain hose is elevated up above the washer. If it is just lying on the floor the water will just come into the barrel & straight out the drain & pump. It needs to be up to cause a loop to keep the water inside the machine, just like the sink trap on your sink needs the 's' to keep the sewer fumes from backing up into the sink or better yet how the s curve in a toilet bowl is there to keep water in the bowl.
This same thing happened to a friends washer after it was installed.
Posted on Feb 03, 2012
  • 350 Answers
Thank You For Using FixYa!
Frigidaire Affinity Atf7000e...Does not load up wa - 725859d.jpg jackiaria Please Rate Me!!!
Posted on Feb 01, 2009
Frigidaire front load washe makes an awful noise when water starts to drain
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Apr 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire Affinity washer stopped working. When i start the cycle it makes a loud humming noise, but no water goes in, and it starts spinning for a few minutes, then the time goes from 1hr, to 3 m
Possible that the inlet valve is faulty. please measure the voltage on the inlet when the washer is switched on , if there is no voltage then the controller is faulty. If voltage is present then the inlet valve has failed.
Jun 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Sep 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
366 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
