Question about Whirlpool LHW0050PQ Front Load Washer
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
MY MOMS HE WHIRLPOOL 27" FRONT LOAD HL04932940 WASHING MACHINE IS LEAKING WATER FROM BOTTOM . IT IS FLLOR STANDING AND INSTALLED WITH A STANDPIPE DRAIN. WARRANTY JUST EXPIRED. I SEARCHED GUIDE IT CAME WITH AND IT DOESNT ADDRESS PROBLEM, PLEASE HELP.
    Sergeant:
  • 291 Answers
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Posted on Jan 07, 2013
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
huuum
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
reg501
  • 413 Answers
SOURCE: Whirlpool WTW5300 SQ Water leaking...Help!!
The water pump is the front and has probably failed.
REMOVE POWER
To access the pump, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling)
Posted on Jun 15, 2008
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
SOURCE: My whirlpool front loader washer leaks water
Check the rubber boot just inside the door. You have to push the drum back slightly and rub your fingers around the entire boot. I had a similar problem and a key had fallen out of a pocket and cut into that boot. The leak would run out of the damaged boot then come out the bottom onto the floor. I purchased a new boot and it took me about 30 min to install it. The problem was solved. If the rubber boot is fine then the over soap thing is probably your problem.
Posted on Nov 20, 2009
Water leaking from bottom of machine when water is going into the load
I suspect that the hose reaching from the water control solenoids to the fill spout is loose or damaged.
Aug 04, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Water leaking from front of washer
you will need to open the machine (front panel - most times its 2 screws on the bottom)
and turn the machine on & look with a flash light where the water come from...is it busted pip , or pump is bad...
good luck
911servicetoday .com
Sep 26, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool top loading washing machine water comes out of the bottom
whirlpool top load washer leaking water into tub with unit in off position
Jun 20, 2009 | Washing Machines
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool LHW0050PQ Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
