Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Why does my kitchenaid ice makes cloudy ice
My ice maker is making cloudy ice, what is causing this
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Stand Alone ice maker leak
Your model number must be plumbed to a external drain.
You may have to install a condensation pump to do this.
Posted on Mar 10, 2009
  • 63 Answers
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
farfield
  • 462 Answers
SOURCE: Kitchenaid stand alone ice maker.
Check and see if your cutting grid is still lined up on the back side towards the freezer plate. I have had the cutter miss align on some and failed to see it then just have to remove the thumb screws and re set the back end. Feel for more roughness from scale. Especially on the sides and edges. you may need to clean it again
This unit I believe is set to allow water in when it goes through a harvest. it wont refill until the coldest temp is reached then will stop filling after the warmest temp is reached.
Posted on Mar 12, 2009
SOURCE: Kitchenaid under counter ice maker:
Kitchen Aid Ice maker is a piece of junk. Best to fix it is to get rid of it and tell friends not to buy it.
Posted on Aug 06, 2010
Why is my ice maker making too much ice?
There is ar thin metal bar that checks for the level of ice on the bucket if the bar is bent our broken it will keep making ice all day
Sep 10, 2014 | KitchenAid 15 " Stainless Steel...
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ksrp25fnbl00 Ice maker stopped producing ice
ksrp25fnbl00 ice maker has stopped making ice. It appears that the water supply that comes down from the top of the interior cabinet is freezing and this is causing the ice tray not to refill. What would cause this?
Jul 09, 2012 | KitchenAid KSCS25FKSS Side by Side...
Kenmore refrigerator ice maker not making ice. Could this be caused by an old, dirty or clogged filter cartridge?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 28, 2010 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool ice maker makes impure ice but the water is crystal clear and good. replaced filter and cleaned ice maker tray ect.... no change. Is there a way to sanitize the water line to the ice maker?
what you are seeing in the ice is the impurities in you water. you wont see them until the water freezes because you are trying to freeze the "H2O" and not the calcium and magnesium. those are what causes your ice to look cloudy.
filtering the water does help but you cant get perfectly clear ice with this type of an ice maker.
when you see "store bought" ice and it is clear, that is because it is made a different way to prevent the impurities from forming in the ice.
also the longer the ice is in your freezer, the more it will absorb from the air causing even more cloudiness.
Jan 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker will not stop sending ice out of door
If your refrigerator has a wire bar that raises and lowers as ice cubes are ejected. Make sure the bar is not trapped or frozen in the down position. This will cause the ice maker to continuously make ice.
Usually pulling the wire bar all the way up the ice maker will stop.
If not, you may have a bad switch and will need this replaced.
Oct 18, 2009 | KitchenAid Refrigerators
Icemaker not making ice Kitchenaide model #KSRG25KSSO4
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees. also check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
Jun 28, 2008 | Refrigerators
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Nov 17, 2007 | KitchenAid KSCS25IN Side by Side...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
144 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
