Not spinning for washing machine
The spinning is not working why?
    Sergeant:
  • 291 Answers
Will need a model # to answer fully. No spin could be from clogged drain hose (hose between drain and pump) faulty pressure switch, timer, or lid switch (if top loader) door switch (if front loader.) Most likely clog or door switch, but need Mod#.
Posted on Jan 07, 2013
  • 3 more comments
  • hilda Jan 07, 2013
    lesl! xqb60A
    spin dry is not working xqb60A
  • B.H. Countryman Jan 07, 2013
    Does it show any error codes?
    You can get owner's manual here, if you don't have one: http://www.manualslib.com/manual/353378/...
  • carla_claus
    carla_claus Jan 07, 2013
    samsung model WF317AAGXAA it will not spingor drain the water
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
My front load washing machine agitate but won't spin
If your machine is rather old or used quite frequently, you should check out the motor brushes. Go to youtube for details on washing machines brushes.
Mar 06, 2015 | Washing Machines
Spin cycle not working
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 05, 2011 | Washing Machines
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
heatman101
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays in the washer and will not drain. Every different wash mode...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 12, 2010 | Washing Machines
Spin cycle is not working . All other cycles are working.
heatman101
Oct 16, 2010 | Roper RAS8445KQ Top Load Washer
MACHINE IS WORKING BUT SPIN FUNCTION MODE NOT WORKING
heatman101
Sep 30, 2010 | LG WFT1071TP Top Load Washer
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
