Question about NEC Dtl-12d dt330 12-button Digital Display Phone univerge Sv8100/sv8300
NEC Univerge call indicator lamp wont stop flashing when there is no incoming call
It also now says "VM" on the top right of the screen. There are no messages waiting, and the voicemail is empty and the night button is off.
SOURCE: nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
Posted on Aug 13, 2008
SOURCE: NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Posted on Oct 22, 2008
  • 10 Answers
SOURCE: nec dterm wont ring in
During an incoming call try holding the up arrow on the volume key. That is the only way I know to increase or decrease the volume of the ring. The phone might also be set on DND. in which case you have to Press feature dial the DND cancel code 69 press feature. If note look for you user guide here. http://www.neccare.com/cng/docs.nsf/Lib3?OpenView&Start=1&Count=100&Expand=6.13#6.13
Posted on Nov 04, 2008
projdoc
  • 2237 Answers
SOURCE: NEC VT 47 projector, status lamp flashes red x 6
the "try again after one minute" is a trial. if the new lamp doesn't work, the problem lies with the ballast.
Posted on Sep 03, 2009
Testimonial: "I guess I will find a repair shop that can check &/or replace the ballast. Thanks!"
projdoc
  • 2237 Answers
SOURCE: blue haze in top right of screen from NEC mt1075 projector
the light filter on the blue lcd panel is fried due to excessive dust and heat. clean out the projector with canned air. unfortunately, you cannot buy individual parts of the optical engine- you'll have to replace the whole thing. or live with it.
Posted on Nov 17, 2009
Wanting to extend ring time - changed by itself - only ringing 5-6 times before going to message bank.
5-6 rings I think that is the best you can get
link to a manual for it
SV8100 DT310/DT330/DT710/DT730 User Guide - NEC Corporation ...
https://www.necam.com/Docs/?id=5601ae16-b7e2-4e8c-a769...
NEC-10645 UNIVERGE SV8300 DT300 DT700 USER GUIDE
au.nec.com/.../SV8300_Handset_Manual-ce03fb6c-32af-4991-9bd5-8ec.
Sep 09, 2016 | NEC Dtl-12d dt330 12-button Digital...
My NEC DVL(XD)Z-Y (BK)phone has a red blinking light for reception button. No one knows the mailbox code since the receptionist was replaced. How do I reset code or stop light from fast flashing red?
These instruction are for a Univerge-SV8100
To Delete a Security code, the greeting, messages or recorded name in a personal voicemail box:
1. From any phone with Admin rights (Usually ext 101)
2. Press the message button
3. Enter security code if there is one
4. Dial 72 to access System Admin
5. Press SUBS soft-key (in display)
6. Dial the extension number you want to change
7. Press the available softkey in the display or 7 to delete the security code.
Be careful when you are in the admin part of the programming because you can really mess up the voice mail if you do something wrong. To check what type of phone system you have look for a NEC box in your phone room or server room. The complete PDF is here
http://www.integratelecom.com/resources/Assets/sv8100-admin-inmail-master-11-5-07.pdf
Jan 23, 2015 | NEC Lands Phones
NEC DT300 has call light flashing red with no call on the line. How do I make it stop?
PUSH JUST THE BUTTON SPEAKER TWICE
IT MAKES THE HAND FREE CALL YOUR PHONE WAS FORGOTTEN ON FREE HANDS CALL
Oct 20, 2014 | NEC Univerge Dtl-12d-1 680002 Dt300 Refurb...
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
The Video Display Screen is indicating "CHANGE
Hi
you ned to change the lamp of flash
Jan 09, 2011 | Sharp Video Cameras
My projector turns on but wont display any images what might the problem be? can it be the lamp?
If it is the lamp there is usually an indication to inform you. A light will flash or change colour etc. If the ballast unit has failed or a fan has stopped working a similar effect will be produced.
Check the indicators and refer to your instruction manual. If you haven't got one or it has been mislaid, browse NEC's web site for instructions.
www.nec.com
Dec 25, 2010 | NEC Office Equipment & Supplies
We use NEC MT1065 and just replace its lamp but it still won't switched on (lamp indicator led is red). How can I reset it ?
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, if your old lamp has only had the reflector replaced then it will make no differance because the chip tells the projector weather or not to power up depending on the hours its counted, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention, just as an added note, a solid red lamp indicator light means that the lamp has expired, if its flashing red this means its nearing the end of its life, if the status indicator light is flashing then there could be another issue, by counting the flashes you can reffer to the manual in the troubleshooting section to diagnose the fault, I know this is very late, but anyone else reading this may find it helpfull.
Nov 29, 2010 | NEC MultiSync MT1065 Multimedia Projector
NEC PHONE-[VM] and Feature Button Flashing
Thanks for the details. i will get back to u soon.
Apr 29, 2009 | Lands Phones
Nec dterm wont ring in
Aug 21, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Nec phone DTU-32D
do you have VM on this system?
Nov 30, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC Dtl-12d dt330 12-button Digital Display Phone univerge Sv8100/sv8300 Logo
82 people viewed this question
Top NEC Audio Players & Recorders Experts
richie46
Trippy Tripp
Outback Jack
Outback Jack
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
