Pilot light on 1996 lp gas furnace burns yellow and makes terrible odor in building
Having a problem with the pilot burning very yellow and sutting badly also making a bad ododr in builing . trying to understand why it is sutting so. its new / pressure switch is new / valve is a new smart vavle/control board is new/ and limit swith is new. also having trouble with duct fan coming on to soon before plenium is heated
  • Heating & Co... Master
  • 2,522 Answers
Pilot needs cleaning sounds like its blocked or change injector in pilot
try blowing out pilot out with air , check afc to see if it is dirty on the back side of it you should be able to remove it and see if it is clean ,also check air filter is clean.
Posted on Jan 07, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
Accurate Joe
  • 61 Answers
Test while the unit is firing with a meter. you should have 24 volts going to gas valve. If you do and no gas is coming out, you have a bad gas valve. You will need a gas pressure test kit to install a new one correctly.
Posted on Dec 01, 2008
  • 14 Answers
SOURCE: Fan switch will not make (limit switch).
If the snap switch is not located close enough to the plenum, this can be problem. The other option would be to cover the switch area with a metal shield or liatherm paper (fire rtardant paper).
Posted on Jan 29, 2008
  • 2522 Answers
SOURCE: Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Posted on Jan 14, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Posted on Nov 12, 2009
My furnace keeps making an explosion when it ignites
The amount of gas buildup is too great. Make sure the burner ports are clear right next to the pilot light area. - run a small wire into the holes to make sure they are clear then make sure the pilot light is burning into the area next to the burner. A bit of whoosh is to be expected but if it becomes too great it will blow the pilot light out. Sears wall furnaces are prone to this the burners have to be kept clean
Feb 02, 2015 | Heating & Cooling
I have a Dayton hanging gas (propane) heater 3E838 series 1067A model z21116 when the heater ignites its like to much gas and blow out the side vents ????
sounds like the air to gas setting is wrong, not enough air intake. there should be an air adjuster near the burn box. where the gas goes into the burn box. fallow the gas line to find it. adjust it till it burns correct. there also should be a gas pressure adjuster to, it should be near the burner.
Dec 26, 2014 | Dayton Gas Furnace Heater
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Why is gas boiler burning black sut gas boiler when it lights up its makes a lot of black smoke and sut.
Burning rich, check for air restriction at burner, possible spider web in tubes etc.
Jan 25, 2014 | Honeywell Water Heaters
Model# BWH30NLTB
Unit goes under sure heat name also.
My unit emitted unburnt gas smell the minute pilot started,
and was annoying during burner operation.
I discovered they built unit with primary pilot that had 2 ports.
They used LP and sealed off natural gas,instead turning lp/nat
knob on back activates second pilot for natural gas use.
This means natural gas goes thru LP pilot orifice and burns
slightly off during normal natural gas use(by design).
The unused natural gas orifice has 1 air mix hole and the LP orifice
has 2 air mix holes.
I carefully plugged 1 of the holes in the LP orifice and suddenly
pilot gas flame seated correctly on orifice port.Gone was the
unburnt odor of natural gas.
The typical flame in a flame appearance now was exhibited by
the small pilot,secondary pilot remained consistent with manual
picture.
Of course, to use with LP I would have to open blocked air mix
hole in addition to the other changes per manual.
Hope this helps someone with similar condition.
Dec 31, 2012 | Reddy Heating & Cooling
Have it hooked to natral gas when it lights it will burn for about 20 seconds fully lit then gos out even blowing out pilot light
The most likely culprit would a faulty flame sensor and they are pretty easy to replaced. Get your model and serial as well as the make of your furnace. You should be able to locate a dealer in the yellow pages.
Dec 23, 2010 | Heating & Cooling
Pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 23, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Flames burn then die down
it sounds like you may have a dirty pilot tube or a weak pressure regulator. I would try blowing out the pilot tube to make sure it is clear and if that does not work then replace the regulator.
Feb 14, 2009 | Dayton Gas Furnace Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
