Question about Yamaha RX-V671 7.1 Home Theater Receiver Black
Hdmi out problem on yamaha rx-v671
No picture via hdmi out
petraman7
  • 1175 Answers
SOURCE: Wii to RX-V363?
Hi..
If youre talking about the set of 3 A/V plugs in the front then you need to connect to the Video Out (yellow) plug in the back that says something like "Front Video" or "video 3" out. Connect that to the display.
Posted on Jan 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: Yamaha reciever doesnt recognise hdmi from Mac laptop
Max does recognize receiver over HDMI-CEC.
The problem is that DVI output is for video only. Macbook won't (and can't) output audio via DVI. So yamaha receives only video signal via the HDMI connector. You can check that by pressing Option button on yamaha remote and choosing Signal Info - you will see info about video, but no audio signal present.
  • 127 Answers
SOURCE: RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Posted on Apr 27, 2010
Yamaha RX-V671 zone 2 no BDDVD audio
Zone 2 cannot pull audio from the hdmi inputs.
Jan 14, 2013 | Audio Players & Recorders
Yamaha rx-v663. Want to watch cable tv while listening to cd (blue ray).
Don't think there is a way to make that happen with your setup
Dec 31, 2012 | Yamaha RX-V663 Receiver
CMK-P3X for yamaha reciver RX-V670
  1. I have a yamaha receiver rx-v670.But it's one of part is damage which we not identified.we found a number on part body.VP832 and XK593 CMK-P3K.Please any one inform me the part name.Thanks.
Oct 27, 2012 | Yamaha RX-V671 7.1 Home Theater Receiver...
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I just bought a Yamaha 5.1 system with rcvr RX-V365 i have HDMI to tv then HDMI to RCVR then another HDMI to DTV. Problem cant seem to get picture AND sound together through RCVR. depending on what setting...
RX-V365 doesn't support sound over HDMI. It can switch the video+audio from HDMI in to HDMI out, but can't play the sound through the speakers. You need to connect the audio separately via optical or coax digital cable.
Mar 19, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
May 22, 2009 | Yamaha RX-V563 Receiver
Yamaha RX-V671 7.1 Home Theater Receiver Black Logo
590 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
