Question about Whirlpool LER4634J Electric Dryer
Wont start up
Please help
  • Sal DeAngelo Jan 08, 2013
    how did you make out with your dryer
  • Whirlpool Master
  • 2,251 Answers
Fist off open the door and check the door switch,it's a little paddle that the door hits,open the door and look at the top right hand side,if it's there push on it with your finger,if it clicks when you push it in then the switch is good.next you're going to need a meter,pull out the dryer,unplug it and remove the cover where the cord connects to the dryer,plug it back in and make sure you have 240 volts coming into the dryer,if so unplug it again,your lint filter is on top so your parts are in the back of dryer,remove the lint filter and remove the back panel,also pull out the lint filter and remove the two phillips screws in front of it,when was the last time you cleaned out the dryer? http://www.searspartsdirect.com/partsdir...
go here and you can see the parts you have to check with your meter.you'll see part 19 on the diagram and part number 3392519,this is the thermal fuse,look on the left side and you'll see the metal duct that the lint filter slides into,to the right of it and down low you'll see a white piece with two wires going to it,that's the thermal fuse,you have to always remove at least one wire when checking them for continuity,set the meter on say 20k ohms,you'll see a number 1 on the screen,touch the two leeds together and you should see anything but 1,now remove at least one wire off of the fuse and touch the leeds one on each side,if you see 1 the part is bad,anything else the part is good,if the fuse is good move over to the right side and you'll see the heater box or metal duct,you want to check parts 6 and 15 on the diagram,if one of those are bad you replace them with part number 279816 here's a site to change out the 279816 t-stat kit http://www.youtube.com/watch?v=VHYg_I90O... this most likely will be your problem if the thermal fuse was ok but if not check part number 20 on the diagram and this is over near the thermal fuse and is replacement part 3387134.the reason why i asked when was the last time the dryer was taken apart and cleaned is one of these parts go bad from the dryer running to hot and the part goes bad as a safety,remove the four screws on the lint filter duct and if you didn't remove the two phillips screws on top in front of the lint filter take them out to remove the duct,clean it out and vac up any other lint you see,also if the vent line is a long run you can blow it out with a leaf blower,if there's a cage or anything on the outside that the lint can get stuck in remove it or clean it out every few months,the dryer should be taken apart and cleaned at least once every year to 1 1/2 years,if it's gas once a year so you don't have a fire.when you get the back together clean out the front of dyer. http://www.youtube.com/watch?v=xGIG8Wo5-N4 go here and see how to take apart. hope this helps,if you need anymore help let me know and hopefully i can help you
Posted on Jan 07, 2013
Changed light bulb on 1993 subaru impreza now car won't start, everything lit up on the dashboard
1993 Subaru Impreza Won't Start! - NASIOC
forums.nasioc.com > ... > NASIOC Technical > Service & Maintenance
Sep 12, 2004 - 3 posts - ‎3 authors The car has been running fine, but recently in the morning especially, it won't turn over. I crank it and its trying to start, but there is no spark. Car won't start, cranks but no start. - NASIOC - North ...
Aug 26, 2013
car wont start, getting fuel and spark - NASIOC - North ...
May 22, 2012
HELP: Car won't start after timing belt change - NASIOC ...
Sep 23, 2008
Weird starting problem--1993 Impreza - NASIOC ...
Mar 4, 2003
More results from forums.nasioc.com
my 1993 impreza wrx wont start please help - ClubWRX.net
www.clubwrx.net/.../134323378-my-1993-impreza-wrx-wont-start-pleas...
Dec 5, 2009 - 7 posts - ‎2 authors can anyone help me, my 1993 impreza wrx wont start, 2 days ago i went to ...ClubWRX Forum - Subaru Impreza WRX and STi Community and ...
Oct 24, 2015 | 1993 Subaru Impreza
My chainsaw wont start
Check to see if it is getting fuel into the cylinder. Does the sparkplug get wet when trying to start?
Jul 18, 2014 | Husqvarna Garden
Truck wont start after driving
Sounds as if you need to recondition your engine.
Nov 19, 2013 | 2004 Ford Ranger
My infinity 1991 wont start i crank it but now it wont start it just acts like it want's to start but wont can you please help me .
Look towards: Fault in the fuel injector sysytem; Battery termional connections corroded or loose; excessive moisture on the ignition components; fuel pump faulty/ fuel filter clogged/ bad fuel in tank; worn faulty or incorrectly gappped spark plugs; broken, loose or disconnected wires at the distributor/ ignition coil pack..
Please provide feedback
Best regards
Ck
Jul 17, 2012 | Infiniti Cars & Trucks
Wont start,even battery is charge.yamaha xjr400
Please check for power on the starter side of the start solenoid - remember to press the start switch when measuring. Should be 0 until you press the switch, then should be 12 V on the DC scale.
Need more help, post here. I want to help you get this fixed.
Thanks for posting at FixYa.com
please vote
Dec 23, 2009 | 1994 Yamaha XJR 400
Psp problems!!!!!!!!!!! please help
maybe you'll just have to check these buttons and replace them
Sep 22, 2009 | Sony PlayStation Portable (PSP) Console
It wont start
Please don't forget to rate if feel this helped you out or when you do find out the problem, please rate the comments posted. Thanks. It helps us help you more!
Greg
May 21, 2009 | 1992 Ford Explorer
My jetta wont start PLEASE HELP
try puttin the key in the door and holding it in the locked position for a few min it worked on mine after i pulled the battery to weld the floor but it took me three days and lots of tryin but thats what i think did it
Feb 25, 2009 | 1993 Volkswagen Jetta
Help my xbox wont start
Sorry, I dont have any experience with games consoles. Please try one of the other experts as one of them will surely be able to help you. My forte are large screen televisions. Sorry that i couldnt help you.
Jul 10, 2008 | Microsoft Xbox 360 Console
Whirlpool LER4634J Electric Dryer Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
