Question about Pool & Spa
I have a shur dri pump that I need a seal rebuild kit for. Where would I find 1?
  • 7 Answers
SOURCE: crosman model 200 rebuild kit for the pump
You can order a crosman rebuild kit from:
Bryan and Associates
Anderson, SC
1-864-261-6810
Posted on Feb 09, 2009
taran_2005
  • 10515 Answers
SOURCE: where can i find pump rebuild kit for simpson
There are so many sites like ebay etc..
The best one is :-
http://www.pressurewashersupplies.com/
Check and let me know, if doesn't find the kit.
Thanks for using "Fixya".
Posted on Jun 23, 2009
sleprocks
  • 147 Answers
SOURCE: have a shur-dri shallow water pump that sputters
This could be several problems, a better description would help. If you have a presure tank the tank can lose air and sometimes need recharging. the regulator to the pump could be bad or out of adjustment. these are the 1st problems that come to mind with water pump problems.good luck.
Posted on Oct 23, 2009
  • 832 Answers
SOURCE: Where can I find a replacement impeller for a
Connect to the internet and type;
http//www.merchantcircle.com/business/Shur.Dri 419-289 1144.
This is where you can find your ShurDri Pump parts.
Posted on Oct 26, 2009
SOURCE: I have a Shur-dri SD-106 pump. I am looking for a
call 888-987-8677 this a division of pentair they make shur-dri pumps
Posted on Jan 10, 2011
Need a rebuild kit for pump not motor
A O Smith does not make a Pump,
they make motors, so...
what pump do you have, so pump rebuild kit can be recommended?
Apr 13, 2014 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Shur dri sdss5
Replace it! It will only get worse and destroy the shaft. If you replace the seal be sure to clean and polish the shaft, it should not be pitted, if so you need to replace it as well.
Mar 15, 2014 | Plumbing
I installed a shur-dri 4"
Hello
If this is a 220 volt pump then it needs to have 2 hot wires,so it would be connected to 2 15 amp breakers.The ground shold run from the pump back to the fuse panel box ground bar.
If this is a 115 volt pump it should be connected to one hot, one nutral, and one ground.
Possible a hot wire is making contact with water and tripping breaker.Or the pump motor is going to ground which means its no good.
Aug 01, 2011 | Heating & Cooling
I just bought a shur-dri a202 deep well pump an need to know if the 1 1/4 discharge can be reduced to 3/4 or will it cause problems
It should be 1 1/4 into the well tank but can be reduced after that. Reducing the line before well tank may cause the well pump to run in excess trying build pressure and shorten lifespan of pum.
RJ
Jul 19, 2011 | Plumbing
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
I have a Shur-dri SD-106 pump. I am looking for a source to purchase replacement impellers. Please advise
Sep 15, 2010 | Plumbing
My Shur-Dri Backup Sump Pump does not activate with a power outage.
I presume your pump is having a separate power supply.
It is to operate if and when there is power outage. Am
I right? Check your Shur-Dri backup pump. Plug it to
another power source, and switch it on. If it runs, then
the problem could be power supply. Have this checked
using voltage tester (multitester set at 300 volts) or you
may use an electric bulb.
Dec 03, 2009 | Plumbing
Where can I find a replacement impeller for a Shur-Dri SD-106 pump?
Oct 25, 2009 | Plumbing
Need a diagram how rebuild kit (o-rings & seals) go in pump
go to your local libary and check for a workshop manual on your make and model it is quite an intense job
Apr 25, 2009 | 1994 Ford Tempo
Pool & Spa Logo
61 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
