Question about Nokia 5530 XpressMusic Smartphone
How to reflash a bricked Nokia 5530 phone with a failed firmware update
Help, phone dead, need flashing while is shutted down
Buntydcmc
  • 121 Answers
SOURCE: I have a Nokia 7610 mobile phone. I want to flash
first download nokia pc suite and conect ur phone with this .
Posted on Nov 19, 2009
murmerjoy
  • 805 Answers
SOURCE: Nokia 1650 Firmware Update
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Updating Nokia Mobile Phone Firmware Here I’ll tell you the things you need to do in order to update the embedded firmware in your Nokia cell phone.
Things to do before a firmware update:
  1. Install Nokia PC Suite, and back up all the stuff from your phone to your computer.
  2. Charge your phone battery to its full level.
  3. Beware that any hindrance (like power off, etc.) during the update process can damage your phone.
Let’s get started.
  1. In your Nokia mobile phone, type in *#0000#
    Your Nokia mobile will now display the firmware version it’s running
  2. Carefully open the back case of your mobile, and also take away the battery.
  3. Note the product number down
  4. Go here and type the product number. You’ll now know if a new version of firmware for your Nokia mobile phone is available
  5. Download the Nokia Software Updater. Click here to download it
  6. Install the Nokia Software Updater (I think it’s recommended to run it if you have more than 256 MB of RAM on your computer)
  7. Connect your Nokia mobile phone via the USB port, and also make sure your computer is connected to the internet
  8. Run the Nokia Software Updater by clicking on the icon on your desktop
  9. The Nokia Software Updater connects to the internet, checks for updates, and then detects your phone to start installing firmware updates for your Nokia phone
  10. You might see some fuzzy things going on in your Nokia phone, and that’s perfectly normal to happen during a firmware update
  11. When all’s done, the updater gives a confirmation message and then the phone restarts
  12. You can now disconnect the phone from the computer
That’s how you upgrade your Nokia mobile phone’s firmware. Let me know in the comments if you have any question.
Posted on Dec 03, 2009
customers184
  • 154 Answers
SOURCE: my nokia 5530 xpressmusic shuts down very time i
The OS on the phone could be corrupted or you may just need to do a master reset to undo any changes done.
Posted on Dec 19, 2009
SOURCE: Nokia 6220 Classic DEAD (black screen)
bogdan744 i have this same problem if you find some instruction to make my nokia work again pls halp mi send me email on shmeko_magionicaro@hotmail.com pls send me anything to make my mobile work again :(
Posted on Dec 22, 2009
SOURCE: nokia 5530 wichs keeps shutting down
my nokia 5530 powers off when i call someone.
Posted on Jan 31, 2010
How do i check nokia 6070 set dead problem?
Can you please be a little me more clear regarding the problem! Is the phone dead now or the phone randomly shuts down and then after some time is able to boot again?
Oct 08, 2014 | Nokia 6070 Cellular Phone
Tip
Flashing motorola phones without a battrey
if you have a dead battery and you want to flash your Motorola phone and you cant do that cause your battery is dead . well i have a solution for you guys . all you need is all usb cable and Motorola rsd lite 3.7 or better now. OK no battery needed remove the battery , on the device hold down the # * buttons than plug in the usb while holding the # * and that should put the device on flash mode that hit start and let the phone flash itself and after its done passed flashing go ahead and insert your battery on the phone and let it charge by it self , easy trick and a tip for the flashing software guys ........good luck from ...rymi1982
on Jun 17, 2010 | Cell Phones
My brand new LG Cosmos Touch phone won't turn on. Installed battery and ran through start-up and phone seemed fine. It then downloaded updated software, still fine. Plugged in charger to charge battery...
I bet you got help and fixed it already, but I had the same problem. Just before it stopped working, I dropped it in a puddle by a curb and I thought that killed it. I didn't realize that my battery was dead! That was it, so charge it!
Feb 18, 2011 | LG Cell Phones
Keeps shutting off
when a phone always shuts off, it is either the battery of the phone is dead,
might need to be charge or replaced with another battery.
you can use another battery to test if it is the battery the fault.
The other thing to check is if the phone memory is weak and may need to be restored
back the phone memory.
will need to be flashed.
if too weak to power up the phone all application you downloaded on the phone has
VIRUS and has affected the phone memory.
First Charge the battery for longer hours before using another battery to confirm
if the battery cell is the problem.
If not battery, in think you will have to flash the phone memory for it to come back to life.
You can use the link below to know about how to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
(unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 | Motorola Mobility Kraveā„¢ ZN4 Cell Phone
Nokia 95 8GB is dead
man check it with a new battery or it may b posible that ur fone s/w is crrupet which need to reinstall by a expert .
Dec 25, 2009 | Cell Phones
N73 shut down when i upgrade the software and wont re-start
DEAR UR PHONE SWITCHED OFF WHILE UPGRADING FIRMWARE.NOW UR PHONE IS NOT STARTING BECAUSE ITS DEAD,NOW TRY TO FLASH IT BY UFS OR TRY IT IN NOKIA CARE
Jun 30, 2009 | Nokia N73 Cellular Phone
Dead...
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is no longer turning on, unfortunately, it needs to be replaced. The unit can not be fixed. The warranty is 90 days from the date of purchase. You would need the receipt in order to receive a warranty replacement.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 30, 2009 | Coby MP-C7085 MP3 Player
Sony Ericsson K700i
Well the little light sais if your phone '''wants'' some recharge or the phone is been in water or the battery is dead (you need to buy a new one)
Aug 22, 2008 | Sony Ericsson K700i Cellular Phone
Nokia 5530 XpressMusic Smartphone Logo
142 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
