Question about Sylvania 6626LG 26 in. LCD Television
Sylvania 6626lg screen upside down - Sylvania 6626LG 26 in. LCD Television
Upside down tv screen
Do the picture to broadcasts appear correctly? Provide more details please.
Gopakumar Gopalan Google
Apr 07, 2014 | Proton MM2701VT 27" TV
Tip
HDMI Closed-Captioning won't go away
I bought this television yesterday, bought the HDMI cord and hooked it up through my Comcast digital cable box. Every channel would display closed captioning, despite it's supposed inability to support that function. In order to remove it, we had to turn off the cable box's ability to display closed captioning. To do that, turn off the cable box and hit menu to get to the setup menu. It is there that you will be able to turn off closed-captioning.
on Jun 16, 2007 | Sylvania 6626LG 26 in. LCD Television
Screen turns white and gets brighter and brighter
Sounds like your screen is shot and need to get a new one
Sep 26, 2012 | Sylvania 6626LG 26 in. LCD Television
My netbook screen is upside down and language is in foreign. How do I change it back?
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key.Restore by pressing Ctrl-Alt plus the up arrow key.ALSOTo change the display from portrait to landscapePress Ctrl-Alt plus a left or right arrow key.Some computers do not have this function.
To change the Language to English - Open Control Panel - regional and Language Option and change the language in Regional Options and change the settings in Language tab and Settings tab.
Jul 12, 2012 | Sylvania G-Netbook
How to get rid of a large gray box that just appeared on screen
Look for PIP (Picture-in-Picture) button on the remote to turn off the PIP function.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 06, 2011 | Sylvania 6626LG 26 in. LCD Television
I have tried for two days to get on my netbook. It says on the screen Loading os Image.... What is happening. Unit is fully charged....
It has a problem finding your windows file to finish loading the CE image. If this is the SYNET07526, then follow the flashing TIP found at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
Be sure to follow the information exactly and insure the SD card that you use is put in the SD slot UPSIDE DOWN.
Feb 16, 2011 | Sylvania G-Netbook
A maroon line running from top of screen to the bottom
Hello; The width of the line means everything. If the line is razor thin, meaning one pixel wide, this is is very likely a bad LCD panel ( costs more than the TV sold for ). If the line is much wider say 1/2" give or take, the problem is the LCD controller or LCD timing ( same thing ) PCB. Much more less expensive! John
Dec 15, 2010 | Sylvania 6626LG 26 in. LCD Television
Black vertical bands in screen. Started as faint shodows now dark
Replace the ribbin cables that connects to the lcd panel. don't have part #
Jun 10, 2009 | Sylvania 6626LG 26 in. LCD Television
Techwood twp 4205 screen doesnt knock on but sound comesout of speakers all green lights are on but no picture
quick easy fix.
white block style ceramic resistors (2 of) on power board.
go to rs components online
part number 199-7696. pennies each.
replace both resistors.
Done.
May 03, 2008 | Sylvania 6626LG 26 in. LCD Television
Sylvania 6626LG 26 in. LCD Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
