Question about Maytag MED9700S Electric Dryer
Maytag dryer epic z flashes error F1 - Maytag MED9700S Electric Dryer
  • Sal DeAngelo Jan 08, 2013
    how did you make out with your dryer
  • Maytag Master
  • 2,248 Answers
Bad thermister part number 8577274 and it's around 30 dollars.go here and see the part
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MED9700SQ0/3048/0151200/W0802068/00003?blt=06&prst=&shdMod= number 42 on the diagram.hope this helps.also there should be a tech sheet with info and error codes on it.don't loose this paper in case you ever have to call someone in to service it
Posted on Jan 07, 2013
  • 3074 Answers
SOURCE: My brand new maytag epic
here is a website that will assist in troubleshooting what is wrong, Good Luck Tim says Whirlpool but it is the same difference :
http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
Posted on Mar 05, 2011
  • 110 Answers
SOURCE: how to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
Posted on Apr 17, 2012
SOURCE: "Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Posted on Oct 24, 2010
  • 3 Answers
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
Posted on Nov 14, 2007
SOURCE: Maytag Epic Front Load Dryer
When you close the door it needs to click twice, the light will go out once its all the way closed........then your good to go
Posted on May 12, 2008
How expensive is it to have a technician repair my Maytag Epic Z dryer with an F-01 error code? I know that the error code is a bad control board.
FIXYA has no idea of labor charges from Maytag service and they do not tell us if asked probably depends a lot on where you live.
Sep 15, 2017 | Maytag Dryers
Epic Z. Why is it flashing pf?
Go to YouTube and type in maytag dryer flashing pf and see if the video comes up, thanks!
Aug 01, 2015 | Maytag Dryers
What does error f 1 mean?
Type Maytag Epic Z error into YouTube and see if the video comes up, thanks
Jun 21, 2015 | Maytag Epic z Front Load Electric Dryer
Maytag epic error code f01
Maytag Epic Gas Dryer
This error code below would be indicated when attempting to start a drying cycle, or after activating the diagnostic test mode.
E1 - flashes if the thermistor is open.
The machine control electronics monitors the exhaust temperture using the thermistor, and cycles the heater relay on and off to maintain desired temperature.
Begin with an empty dryer and a clean lint screen.
  1. Plug in dryer or reconnect power.
  2. Set the following configuration:
Door - must be firmly closed Press CONTROL ON Press CYCLE END SIGNAL (Loud) Press HOLD TO START
3.
If after 60 seconds, E1 or E2 flashes in the display and the dryer shuts off, the thermistor or wire harness is either shorted or open.
  • Unplug dryer or disconnect power
  • Check wire connection at the machine control electronics and thermistor.
  • If wire connections are good, remove the two wires from the thermistor and replace the thermistor.
  • Plug in dryer or reconnect power
NOTE: All thermistor resistance measurements must be made while dryer is unplugged or disconnected from power.
Thermistor resistance: 10 Celsius ----- 19-22 kOhm
16 C ------------ 15-17 kOhm
21 C ------------- 11.5-13.5 kOhm
27 C ------------- 8.5-10.5 kOhm
32 C ------------- 6.8-8.8 kOhm
38 C ------------- 5-7 kOhm
If E1 or E2 doesn't flash in the display, the connections to the thermistor are good. Therefore, check exhaust temperature value at any or all of the temperature levels.
Hold a glass bulb thermometer capable of reading from 32 to 82 Celsius (90-180 F) in the center of the exhaust outlet.
Table below shows correct exhaust temperatures:
24385279-wycorcio5u0xxoh2plbhrodj-5-0.jpg 24385279-wycorcio5u0xxoh2plbhrodj-5-2.jpg Dado
May 10, 2014 | AEG Dryers
Maytag dryer epic z how to reset f1 code it is flashing
https://www.repairclinic.com/RepairHelp/Dryer-Repair/8-4-698588-/Maytag-Dryer-MEDZ400TQ2-Troubleshooting
The above web page should help you with any issue concerning this unit. Check back if you need more advanced information.
Thank you/
Jan 19, 2013 | Maytag Dryers
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
Apr 25, 2009 | Maytag EPICz Electric Dryer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Maytag MED9700S Electric Dryer Logo
441 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
