Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
We ran our 9 gallon Ridgid without a filter (Silly boy) Now I need clean the exhaust. The entry to which is clogged. Any easy way - without breaking it, to removed the plastic mount the filter fits on to.. ? Please.
  • Ridgid Master
  • 18,411 Answers
This video may help you
Posted on Jan 07, 2013
  • Allan Bacon
    Allan Bacon Apr 16, 2013
    thank you, yes, it should help considerably....
JSEhandyman
  • 368 Answers
SOURCE: Water isdischarging from the exhaust of my new Ridgid Wet/Dry Vac
Hi Robinm61,
I always have the filter in - - it helps protect the motor.
If you're going to vac liquids, I recommend use of an intermediate trap to stop most of the liquid from getting to my vac (makes clean-up a LOT easier). A cyclone-top (available at Rocker.com, for example) fitting on a 5-gallon pail works great. The liquid is mostly deposited in the 5-gal pail, and doesn't gum-up the guts of your vac. You need another section of hose, but that's another one of those tools that is hard to have too-much of. (Rockler also sells a nice hose as part of it's Vacuum Tool Kit - also at Rockler.com). Photos (courtesy of Rockler.com) follow below.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 29, 2008
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
anderza
  • 41 Answers
SOURCE: Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Posted on Jan 05, 2010
SOURCE: I am unable to take old filter off my Ridgid
You press in the black cap in the middle of the filter while you pull up on the black "handles" around the edge of the filter. It just pops off.
Posted on Feb 16, 2011
SOURCE: ridgid shop vac is not sucking
I was using my ridgid wet dry vaccum when it shut down by itself and never restarted. I unplugged it and and checked the wall outlet which had power. What caused this to happen?
Posted on Jul 13, 2011
I am unable to take old filter off my Ridgid portable 4 gallon vac.
Jan 20, 2011 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have cleaned out the vac and changed the filter but I can hardly **** up leave on the garage floo.
Try this:
Detach hose, turn on vacuum, hold hand in front of intake to check airflow/suction. If it seems good, you either have a clog in the hose, are bad leakage.
If it's a clog, try placing end of hose in the exhaust port, turn on machine, and blow clog free. You may need to place other end into intake. This should clear it.
If hose is cracked, punctured, or smashed/collapsed, replacement will be necessary.
If there's not much suction at the intake, it may be time to replace your vacuum, or at least the motor.
Nov 13, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
Jul 08, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
208 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
