Question about HEWLETT-PACKARD Pavilion Desktop with AMD Athlon II QuadCore Processor (P6310Y)
Is this computer able to dual boot win 7 and xp
Running win7 tried to set up dual boot but when booting from disc "xp install disk" computer crashes to blue warning screen. not sure this computer can run with xp. my computer is 64 bit running pre-installed win7. made space on my hd for winxp restarted,boot from disk, started install of temp files then crash to blue warning screen. thank for tour time
  • HEWLETT-PACKARD Master
  • 27,725 Answers
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Posted on Jan 06, 2013
  • 5 more comments
  • collmazzoni
    collmazzoni Jan 07, 2013
    Hi Brain, thanks for such a fast return. My xp install disk is 32 Bit os.. Is it ok, that I did it this way? went into disk manage and shrunk drive cTo make a new partition. formatted ntfs and then with the xp install disk in the drive rebooted from disk. Thats when i get the blue crash
  • Brian Sullivan
    Brian Sullivan Jan 07, 2013
    You will need a 64 bit copy of xp the hard drive is formatted 64 bit
  • Brian Sullivan
    what version of xp home or pro ?
  • Brian Sullivan
    http://support.microsoft.com/kb/322389
  • Brian Sullivan
  • collmazzoni
    Hi again I had success in installing xp 64 bit pro. but seems the hardware that i am trying to use can only be updated on a 32 bit system. why won't 32 bit install on my 64 bit computer
  • Brian Sullivan
    Brian Sullivan Jan 08, 2013
    what are you trying to say its sounds like conflicts to me what hardware ? are you trying to use. Beginning with the release of Microsoft Windows Vista, 64-bit operating systems are slowly becoming extremely prevalent in today's market. 64-bit operating systems are poised to eventually replace 32-bit operating systems entirely. At the present however, 32-bit applications still vastly outnumber 64-bit applications. Luckily, 64-bit operating systems are capable of running 32-bit operating systems. In 64-bit operating systems, 32-bit applications are installed to a second program files folder, named "Program Files (x86)." Programs installed in the x86 folder can be initialized just like programs installed in the regular Program Files folder. Open the 32-bit programs folder. Go to Start > Computer > Local Disk (C:), then click on "Program Files (x86)." Open the desired program folder.The executable file for the program will be located inside the folder. Double-click on the file with the ".exe" file extension. As an example, for the QuickTime program you would double-click on the "QuickTimePlayer.exe" file. You have now successfully run a 32-bit application in your 64-bit operating system.
5 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: how do i get srs audio sandbox to work on my pc? win7 64-bit
if you mean audio soundbox
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Posted on May 08, 2012
  • 1011 Answers
SOURCE: windows xp will not start on my packard bell i media
press F8 very after it start (just in starting mode) you will get the options for booting. Select SAFE MODE and check it will start in that. Once it is started then it will work on normal mode. If problem persists then you have to restore the windows with Window CD/DVD. If you don't want to install a fresh copy just recover the previous one.
best of luck!
Posted on Mar 08, 2012
  • 212 Answers
SOURCE: My computer crashed message I get is windows could not complete installation to install windows on this computer restart installation
Get a new copy of the operating system and probably you can also change the CD drive. It might be a reason that the CD drive can not read the CD on which the Operating system is located. Another option is to get an external CD/DVD drive that will also help big time. Try to install and see if it will refuse again...Normally your problem is caused by the scracthes on the CD with the operating system and or the CD drive that is being used, being sensitive to scrathed parts on the cd.
Posted on Apr 20, 2012
wyman307
SOURCE: After Upgrade the RAM in
I was having the same Memory Parity error on a bunch of xw 4400's that we are refurbishing with 8 GB RAM and Windows 7 64-bit SP-1. They came with an NVIDIA Quadro FX 560 card. The whatever-you-get drivers from Windows Update for the video card were causing the error. I downloaded and installed new drivers, released in May 2012, from the NVIDIA website and the trouble went away.
Posted on Aug 21, 2012
Sir, i am using windows 7 ultimate. i would like to install another one operating system (i.e) windows xp professional. now i insert the win xp professional disk into it but the install windows xp is...
boot your computer with windows XP cd. it will install winXP automatically but remember to install windows XP other than the drive where your win7 is. for examp: if your win7 is in C drive, install XP in D drive. hope you can do.
Aug 29, 2011 | Computers & Internet
I have want to setup Windows xp and windows 7 together .Meaning when start up computer have : Windows xp Windows 7 I try to setup two windows ,but i setup windows xp lost windows 7 and setup windows 7...
Not sure what you have done so far. You need to divide your hard drive into two sections. Install XP first on to one section. Then use a program to manage your computer start up, the one I use is called Easy BCD this is a free program and works great. Once you cut your hard drive and install XP make a copy of your start up partition. Install the Easy BCD program and make a back up again. Then Install Win 7. Then on the Win7 side install the Easy BDC program and set up the menu choices. I run a 3 way boot with XP and Ubuntu. Hope this helps Fix Ya up.
Jul 09, 2011 | Computers & Internet
I have duall opreating system. One is xp another one win7.When i format my laptop.than load first xp-32bit.Than i load win 7.after finishing all the win-7 instlation.restart the system than i feace the...
Hi.
The "tfght" message means that some of the files, folders and sub folders are compressed.
Boot the Windows 7 DVD, choose Custom install, on "Where do you want to install Windows" screen, click on Load Driver. Now use the mini-explorer which pops up to rightclick on System HD then choose Properties. Uncheck "Compress Drive to save Disk Space" for All Files and Sub-Folders. Restart.
That should solve the problem.
However you may have to start again. Click on the link below for an in-depth guide on how to dual boot XP and Windows 7.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html?ltr=D
Good luck and regards.
Jun 09, 2011 | Computers & Internet
I have lenovo z560.. and windows xp sp2 installed on it along with win 7. when i m trying to install audio driver, then it displsys a error message "" could not find media device for this...
Do you mean you are running a dual boot system? Meaning that you can boot to Win7 or Win XP? If you boot in XP then you will have to manually have to install sound card driver. Really need more details to be able to help you better.
Feb 25, 2011 | Computers & Internet
In my lenovo z560 laptop win 7 working good but win xp not installing. it is very hard problem with me please solve this problem thank you contacat no. 9891870025(Delhi 53)
Enter Bios , Disable AHCI and Enable IDE if you want to install XP
(You may find that configuration in advance settings in BIOS)
Dec 30, 2010 | Computers & Internet
Making printshop 21 run properly on win 7
You can either get Broderbund Print Shop Deluxe 2.0 which is Win7 compatible or use a virtual/dual boot computer with WinXP. (The Vista compatible version was Print Shop 23; so you are dealing with some significant changes in the OS. Thus the compatibility mode probably won't work. You can try right clicking on the installer and choose Properties and the Compatibility Tab. Check Run as Compatible with XP then right click on the installer again and choose Run as Administrator. Then do the Compatiblity mode again with the actual program.)
With Win7 Pro and Ultimate, you have an option to download and run XP mode which takes two programs that you download from Microsoft and install. This lets you run a virtual XP computer inside the Win7 computer for free. All other virtual computer programs or dual boot systems require a licensed version of XP.
I hope this helps.
Jul 31, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
Have Win7 on Dell laptop and need to dual boot with Win XP.
Why do you need to duel boot???
It is impossable for Windows XP to be Duel Booted to Windows 7.
There IS a way, but it would be to hard
Dec 29, 2009 | Dell Studio 15 Laptop
HEWLETT-PACKARD Pavilion Desktop with AMD Athlon II QuadCore Processor (P6310Y) Logo
102 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
