Question about Polaroid TDX-02610B LCD TV
Polaroid TV is making a loud fan noise? What is this and can it be fixed?
jsinex2421
  • 62 Answers
SOURCE: my 1.5 yr old Polaroid makes a loud buzzing noise for about 5 min
That would be the infamous color wheel. They become warped, cracked, and just plain worn out over time. A replacement is around 200 bucks. If you have intermediate mechanical skills you can replace it yourself. It is located right next to the lamp. There will be a "rounded" section with a few screws holding it in. Remove the lamp assembly from the light engine and the color wheel will b easilly acessable. There will be one set of wires leading from the wheel itself.
Posted on Jan 10, 2009
budmrtn
  • 11361 Answers
SOURCE: polaroid tv made loud noise and died, changed fuse
You can get service manual here: http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look for standby 5vdc power supply, you must have this first before looking for anything else.
http://en.wikipedia.org/wiki/Capacitor_plague
You may need new poer supply module.
Posted on Dec 06, 2009
budmrtn
  • 11361 Answers
SOURCE: polaroid flm-3232 powers on but makes a loud
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Polaroid+FLM-3732+
Please post back what you find
Posted on Dec 18, 2009
maatmartin7
  • 1213 Answers
SOURCE: We have a Polaroid 37" HD tv that has a loud
You have weak capacitors in the power supply and the signal board. I have not repaired this particular unit, but have experienced this with other Polaroid TVs. You will need a TV tech to replace those capacitors. It is a very time consuming task and requires patience and much care to remove the capacitors. Tell a tech that they must be very careful when they remove a cap in the signal board, as they can peel off a pcb trace. In most cases they replace the signal board, but the capacitors can be replaced! Thanks for asking and show a few hands of support!
Posted on Jan 03, 2011
caroldon
  • 17130 Answers
SOURCE: Polaroid flm-373b lcd tv - making a loud buzzing
Possible that the main power supply unit which is the SMPS- switch mode power supply- has a faulty capacitor or in the INVERTOR board which has changed the value and so the frequency being changed can cause higher huming level- reduced to lower frequency.
so check the board for leaks , if so replace. Also check if the threshold voltages are below level in these circuits. if so the capacitor can be identified. If there is change after the component heats then simulate the circuit board and confirm using a hair dryer.
Posted on Sep 23, 2011
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Jan 03, 2011 | Polaroid FLX-374 37 in. LCD TV
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Polaroid Model 3200 started with no sound then
This happened to my tv as well. I have a 62 inch polaroid. Were you able to fix your tv. If so what did you do and how much did it cost?
Sep 05, 2009 | Polaroid FLM-3232 Television
Loud whistling noise coming from tv speakers
a couple of things could make the tv chassis whistle
1 coud be dry solder joint probably on power capacitors
2 IF your tv has tube the board on the back could be making the noise its to do with the yoke on the way out!
Jul 13, 2009 | Televison & Video
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid FLM 3232 is making a loud crackling noise overpowering volume
Your only solution is to change the sound to mono. Eventually the power supply will go and the tv won't work.
Mar 19, 2007 | Polaroid FLM-3232 Television
Polaroid TDX-02610B LCD TV Logo
24 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
