Question about Ovens
Why does my Jenn-Air Double Oven continually chime when both ovens are in use?
(jjw2730ws) After both ovens reach the desired temperature the audio chime continues to go off periodically and quite frequently. I have cheked to make sure that racks are pushed in and that doors are closed completely. It has not made a difference. Any suggestions?
  • relaxinrod
    relaxinrod Jan 31, 2013
    Mine too! Very annoying! Nothing in manual!
3 Suggested Answers
SOURCE: Jenn Air electric double wall oven model ww2780B
A similar condition in our oven, finally resulted in an "F1" error message on the control panel/ keypad. A replacement of the control panel seems to be indicated. The part is available from several different jobbers: part # AP 4283616. A service call prompted our order of this part; hasn't arrived yet, but will post when in and working.
Posted on Nov 05, 2008
  • 71 Answers
SOURCE: MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
the ignitor is prolly bad (not pulling enough amps)
Posted on Dec 24, 2008
The ovens no longer get up to temperature. And if you do get it to a temperature, it does't stay at that tem. It just continues to get cooler.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 12, 2010 | Jenn-Air Electric Double Oven
Dim displlay on oven controls. Dim all the time, as oven heats to desired temperature, controls are not legible.
SEE INFO AT THIS LINK: http://www.fixya.com/support/t4256191-ww304430p_lights_control_pannel_very_dim.
Or use "Dim Display as search term.
($5.00 +/- DIY fix if it works, sure did for me.)
May 24, 2010 | Jenn-Air JJW8230D Electric Double Oven
When baking a cake or bars the oven is set to the recommended temperature and baked for the recommended time and the middle doesn't bake all thru.............gooey.
Put a thermomiter in the oven and set oven to 350. Once oven says it has reached temp. Give it about 15 min and check the thermomiter you placed in the oven to see if it maches.
This is where I would start.
Jan 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
I have a Jenn Air ww2711w0 double oven. The Lower
Your t-stat or control board could be out on this unit. Can you check your t-stat and see if it's working alright? If it is, it's probably your board. Hope this helps~!
Aug 20, 2009 | Ovens
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
