It made great coffe in the morning, after use we turned it off, and by lunch we turned it back on, it was heating like usually and then sut off all of a sudden... I opened it up and could not tell what was wrong, touched nothing, put it back together again and tried to turn it on again, it started and was heating like normal for a while and then shut off again. Now, several hours later it is not doing anything when i hit the switch, no light on switch, no pumping or heating, dead... I can't find a reset button, is there one and how does it look/where is it located? Thanks for the help!
SOURCE: No hot water
Yes there is a small red breaker switch on the left side of the boiler tank. Unplug the unit first then remove the left side cover and just push down on the red breaker switch to reset it.
SOURCE: Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
Testimonial: "Had the problem fixed in 5 minutes. Saved me a lot of inconvenience and (probably) money. Thanks for the solution."
SOURCE: My Rancilio Epoca ST1 would not turn on yesterday
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
