Kemmore elite washer machine which cod is for replace main board
    Sergeant:
  • 291 Answers
Codes F4 through F16 indicate electrical problems. There is no code that indicates main board failure specifically. If you go to www.searspartsdirect.com you can type in your model # and find much info on your machine. Including most manuals available.
Posted on Jan 06, 2013
Kemmore elite oasis model # 110.28042701 type 581washing machine not turning on.
Make sure it is receiving power. Having confirmed this what works and what does not. Resubmit your inquiry with specifics so help can be rendered.
Nov 23, 2015 | Kenmore Washing Machines
Kenmore Elite HE 3t steam washing machine shows a code of F71
The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
Kemmore elite 3t has error code f and will not drain
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
The code is a door lock error!
Nov 25, 2010 | Kenmore Elite HE5t Washer
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Error # E5E
this is a communication error between the main contorl board and the speed control board check all the wiring harness and make sure they are in good order.replace the main control board if the problem continues replcae the speed control board
Mar 15, 2010 | Kenmore Elite 45986 Front Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
