Question about AOC L24H898 24 in. LCD TV
My l24h898 tv will not display a menu and has a white hue over the picture
Toshiba 19DV500B screen has a white hue on tv picture, how do I resolve?
If the tv menu is also messed up then the lcd panel needs replaced. if not under warranty replace the tv.
May 08, 2014 | Televison & Video
Colors are wrong
Do a factory reset:
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Dec 24, 2013 | AOC L24H898 24 in. LCD TV
Flat screen tv cant get menu to come up
If there in no menu display, the main digital board to your TV shoule be checked. Contact any service technician.
Jul 15, 2013 | AOC Televison & Video
My picture is pinkish and glossy
If the overall picture has a pinkish hue to it and skin colors appear to have pinkish blotches. White scenes have a pinkish hue to them then it is is likely the main display board, 6871QCH029A. This board is located next to the Y sustain board. Need to remove the tv from the stand to get to the main display board. I just fixed my Z50PX2D that had the pinkish hue to it by replacing the main logic board. Check ebay for boards.
Jun 23, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Both the picture and sound work when the TV is turned on, yet the picture is distorted like a double picture and has a yellow hue to it.
Sounds like you have a convergence problem. If you go into the setup menu of your TV, there should be some settings to adjust the red, green and blue hues and re-position them so each color matches up. If this does not work or if you don't have a menu, your TV *might* have a circuit board with several plastic screws on it. These adjust the picture and it's a very tedious task to re-align each hue correctly.
My projection TV is an older model from 1995, which is probably why it has this circuit board in place of a convergence menu built into the TV.
If adjusting the convergence still doesn't work, you might need to purchase a new convergence chip.
May 20, 2011 | Sony KP-51WS520 51" Rear Projection...
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
Sony projection Tv KP-65XBR10W has no picture or sound
I had a Sony recommended serviceman come in to analyze te same problem for me. Turned out to be a major part called the 'D' board. Cost for part around $400 if it could still be gotten and at least $300 in labor. Goodbye TV! My money will be better spent on a replacement LCD/Plasma TV since prices are dropping and picture quality will be dramatically better than the old beast.
Dec 30, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony Plasma KDE-P42XS1 Television
We had the same problem discovered it was the TV bulb was going out. Thought the light would blink before that happened according to the book but found out it only blinks when it goes out completely. Buy the bulb and put it in yourself, it's easy and will save you at least $100.00
Dec 29, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
AOC L24H898 24 in. LCD TV Logo
20 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
