Question about GE DCVH515GF Gas Dryer
GE DCVH515GF Gas Dryer ignitor part number - GE DCVH515GF Gas Dryer
    President:
  • GE Master
  • 1,922 Answers
G.E. part # WE4X739 round ignitor
Posted on Jan 07, 2013
5 Suggested Answers
  • 686 Answers
SOURCE: GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Posted on Feb 27, 2009
SOURCE: No heat. Assuming ignitor is bad. How do you
Thanks for getting back. I did fix my dryer. After viewing exploded views of the dryer cabinet (on-line) and learning where the ignitor was located. I removed it, checked the resistance and discovered some corrosion had built-up on one side of the ignitor. I scraped it away, re-assembled everything and it worked.
Posted on Jan 26, 2010
marka19
  • 1430 Answers
SOURCE: just put a ignitor for
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Posted on Mar 03, 2011
heatman101
  • 43501 Answers
SOURCE: GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
-GE model DCVH 515 Dyer control panel say locke . will not unlock as per instructions
Trying uplugging and let set for 5 minutes and start again. Had the same problem and that fixed it for me. Hope this helps
Feb 22, 2014 | GE DCVH515GF Gas Dryer
What is the size of my dryer
Go to the General Electric web site using your internet connection and put in your Model Number then download the operator's manual...it should tell you what you need to know!
Dec 25, 2012 | GE DCVH515GF Gas Dryer
Dryer turns on and lights , heats approx. 1 min. goes out when up to temp, stays off approx 1min. lights again, may do this for 5 times then just doesn't relight. Stays cold, keeps spinning drum. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | GE DCVH515GF Gas Dryer
Dryer heats up for about 10 seconds after start up, then the flame goes out.
heatman101
Nov 30, 2010 | GE DCVH515GF Gas Dryer
Dcvh515: dryer does not heat. Replaced the ignitor. Still no good
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 03, 2010 | GE DCVH515GF Gas Dryer
No heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tttr
May 16, 2010 | GE DCVH515GF Gas Dryer
My dryer runs but does not heat. I have a gas dryer frontloader about 4 years old
Most gas dryer no heats are cuased by a faulty ignitor...
Check out this tip that I wrote about your problem...
heatman101
Apr 01, 2010 | GE DCVH515GF Gas Dryer
DPXH46 GE gas dryer won't stay lit. Already replaced igniter and selenoid coils. What now?
sounds like the vent line is clogged with lint clean out the dryer and take the vent line off the back and blow out the line with a leaf blower,check outside and make sure the air is blowing open the flapper
Oct 30, 2009 | GE DCVH515GF Gas Dryer
My gas dryer is not heating anymore, but it still tumbles. A pilot or ignitor light does come on for a few seconds when I start it but then it goes out. Is it supposed to stay on or is that normal and...
It is not getting gas. Either there is no gas getting to the valve or the two solenoids ontop of the valve are faulty and need to be replaced. The fact that the ignitor glows means the thermo fuse is ok.
Sep 22, 2009 | GE DCVH515GF Gas Dryer
Scraping/high pitched noise in GE model DCVH515GFOWW.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
Open Questions:
GE DCVH515GF Gas Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
