Question about Security RS1050 Remote Start Add On
Need troubleshooting guide for a stellar rs1050 remote start
I am having trouble with my Nissan Tida Ignition immobilizer car refuse to start with the current device how do repair or determine the problem I thank you kindly please respond asap
Posted on Jan 08, 2014
  • 139 Answers
Remote start systems usually do not have troubleshooting guides. What is the problem you are having?
Posted on Jan 08, 2013
  • 4 more comments
  • matt smart Jan 09, 2013
    well the short of it i have a ford f250 2006 model i used a white and red wire for the actavation input and does not work i myself found a wire that would work the unit worked for a few tries but after about 2 minutes of run time the unit starting clicking out of control and the dash lights were flashing i turned it off and checked wireing and tryed it again and the same so shut down and looked over wiring again and then tried it and nothing it will not work i do not know what is going on conacted the manufacture and they were no help
  • Alan H Jan 09, 2013
    Your description sounds like a ground problem. Check and make sure your ground connections are solid. Where are you grounding the green/white and black wires? Ideally the resistance between the battery ground terminal to the ground mounting point should be less than 0.1 ohms. If it is not find another location. Ensure that you use a proper sized ring terminal and NEVER just wrap the bare wires around a screw for ground purposes.
    Thanks I will check it out and let u know I am use some of the metal dash brassing for a ground I will find a factory ground and put there post back when get it done thanks again
  • matt smart Jan 10, 2013
    ok checked the ground and it is good the unit is not responding at all the red light on the front of it is on but no reaction i think when the relay started clicking on and off so fast it may have blowen can't replace to find out because soddered to the board dont know am lost still
  • Alan H Jan 10, 2013
    If the LED is lit, it may be in valet mode. Try turning on the ignitin with the key and then press the valet button.
    Yea thought the same tried still nothing I believe it is defective and I'm returning and getting another thanks for the help will up date when receive new and install
How to install Remote start on 08 nissan pathfinder
First, if you are not skilled at auto electrical systems...this is not a project to take on. You will be cutting into high-current wiring and any mistakes can result in damage to the vehicle and possibly personal injury. These devices are not plug-and-play. They often need additional modules depending upon the year and model vehicle they are being installed in. I have personally installed three of these type systems. One was on an older car without alarm/immobilizer. It took me 12 hours to install and test. The next was on a 2006 Impala. I needed a second module and it took a week of evenings to install, test, and troubleshoot. The last one was in a Malibu Maxx. It was the hardest due to the tight working conditions and the non-availability of reliable wiring diagrams. If you cannot get the information you need to install this system from the documentation provided with it and from anything else you can find on the manufacturers website, my advice to you is "If you have to ask, you're in way over your head!"
Jan 13, 2015 | Security RS1050 Remote Start Add On
Need instructions to install stellar rs1050 remote start for 2008 toyota 4 runner
Secure unit in box and carefully lift with both hands. Place unit on shelf and call local professional installation technician.
Feb 05, 2014 | Security RS1050 Remote Start Add On
What color is the trigger wire between the nuetral safty switch and ignition
You did not specify which the year and model of your Saturn but typically Saturns do not have neutral safety wires that need to be interfaced with a remote start system. Depending on the remote start system being installed will determine the wiring method needed.
Jan 05, 2013 | Security BYPASS Vats Passlock Passlock 2...
Security RS1050  Remote Start Add On Logo
251 people viewed this question
Top Stellar Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
Terry Hair
Are you a Stellar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
