Question about Nintendo Wii Console
My wii u game pad is stuck my son he played you tube than after its not work I did power off sync but still it not work
Active video stuck
SOURCE: Wii LED Green, but no Startup on screen. Cannot power off either.
Just spoke to Nintendo Technical support.  Seems the rub is in the AC adapter itself.
Need to power down at both ends of the AC adapter--unplug AC adapter from wall output AS WELL AS from back of Wii.
Wait at least two minutes to allow any charge in the adapter itself to dissapate.  Plug adapter into wall first, then back into the Wii, making sure your peripherals (eg AV receiver, TV, projector if using) are already on.
Tech support says sometimes you get a partially tripped "fuse" within the AC adapter itself.
This seems to have worked for now--will let the forum know if further problems
Posted on Jul 27, 2008
john_n4
  • 73 Answers
SOURCE: wii suddenly freezes during play?
You should make sure your disks are not scratched. To turn the wii off (without unplugging and all that).....Just hold the power button for a while on the counsle until it shuts off. Just out of curiousity.......and maybe a thing.........because this happened to me.........it froze because i entered a cheat and skipped to much in the game, but when i went back and did it the real way, it didn't freeze.
--John
Posted on Nov 24, 2008
SOURCE: ds game stuck inside wii
lol funny situation now maybe you should get either 2 very thin peices of wire or something sort of solid and fish it out or unscrew your console and if there are wires hanging from bits just dont touch them and keep unscrewing and remember were you took the things out from then when you get to the cd slot take the ds card out and that should work good luck
Posted on Dec 27, 2008
  • 14 Answers
SOURCE: Gamecube disk stuck in Wii console
If there is a game stuck inside the system, nintendo will want to have it come in for repair so they can safely remove it and get it back to you, if youve had it with in a year they should do the fix for free. Give them a call and see what they have to offer.
Posted on Jan 23, 2009
  • 25 Answers
SOURCE: A gamecube game is stuck in wii... Please help...
You may check out Wii Fix Guideto fix the problem yourself. This DIY guide will show Step by Steppictures to fix the problems yourself without any technical knowledge.
Posted on Feb 20, 2009
We connected the wii u to my sons tv but nothing appears on the screen and it only appears on the game pad
Make sure the tv is in the correct input, as in, hdmi 1 or 2. I think the set up process requires you to use the pad first.
Jan 04, 2014 | Nintendo Wii U
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
Dec 01, 2011 | Nintendo Wii Console
The sync button on my wii console is stuck and I can't sync any of my wiimotes thus rendering me unable to play a game. How do I fix it?
If the red button still pops out, but the button inside is stuck, you could give the red button a few solid taps with the tip of a finger. If it's the red button that's stuck and won't pop out, take a piece of tape, stick it to the button, then pull the tape off in a fast motion.
Mar 24, 2011 | Nintendo Wii Console
My son was playing his wii and set down the controlers for about ten minutes came back to his game and its like it cant see the signal. I dont know what happened or how to fix it. I have tried unplugging...
Your Wii controller has a power saver function built into to turn off the controller and save battery life. If it's not recognizing the controller, try rebooting the Wii. If that doesn't work then your Wii controller needs to b re-synced.
http://www.ehow.com/how_2144692_sync-wii-remote-controller.html
If it's not powering up at all then the batteries need to be replaced.
Jan 06, 2011 | Nintendo Wii Console
I bought rock band 3 for wii. I plugged in the dongle for the keyboard and followed the sync instructions exactly. the lights flash on both devices, but when I let go of the sync buttons, the lights on...
This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
Dec 31, 2010 | Rock Band 3 Wireless Keyboard
I have a problem with wii console.. I can choose everything in the menu, wii recognizes while I am in the menu part but when I am entering to wii sport I can not play the games.. It doesnt capture the...
1- Try to press home button ,if it loads u can sync the remote from there.
or
2- Try to re-sync your remotes by pressing both sync (from remote and wii at same time) in the game.
or
3- You can get a new remote and see if it works during playing . If it does your previous remote isn't working properly, but if it doesn't there is a problem in either the game or wii (bluetooth module)
Feb 27, 2010 | Nintendo Wii Console
My daughter stuck money into the Wii console, now it will not play game discs.
my son had stuck two quarters in our wii and my husband opened it up and took them out. it started playing right after that.
Nov 15, 2009 | Nintendo Wii Console
Wii remote
did you try re-syncing it... i thiknk there is a button on the back of the wii-mote, benoeath the battery cover.. a little red button... that sync's it to your wii... try that and try taking out the battery for a few seconds.
try reconnecting your wii sensor bar to the wii...
i don't think you can overcharge it.. my girlfriends cousin leaves it on the charger 24-7 and it works fine.
Sep 11, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
105 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
