Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
InSinkErator Badger 5hp NOISY
2 YRS old - I reset it; I used allen wrench to try to unclog a clog - nothing in there! When I run it it RATTLES as if there are loose parts clanging around in there. What could that possibly be? If I felt free to run it with all that noise, I do think it runs fine/grinds things/does not clog. Help!
  • 1 more comment
  • GlyndaR Feb 14, 2009
    Our Badger disposal starting making a noise that sounded like the blades weren't balanced or something. It grinds fine and works fine. It's only about 6 mos. old, but I would like to find out what's wrong with it before I use it anymore.
  • tedwcaldwell Apr 01, 2009
    there's nothing in it. the rattle is intense and sounds like something broke loose inside it. it's definitely a metal on metal noise.
  • pdrva May 23, 2009
    I installed mine about 2 months ago and it ran great until a couple of days ago. Now it vibrate like crazy and makes a loud noise to go along with it. Not a loose part kind of rattle sound but something is not right. I reset it and that didn't help.
I had the same problem.  I felt around and felt nothing in there like a spoon or whatever.  I shined a flashlight down in there and couldn't see anything.  I ran it again, and shined the flash light down there.  Finally, I noticed a dime in the bottom.  I couldn't feel it, couldn't see it on the first look, but as soon as I removed it, problem solved.
Posted on Aug 19, 2009
  • Teresa Chandler Feb 02, 2012
    AMAZING! I have had the metal on metal sound for months and couldn't see anything in there. I even felt around ( power off!!!) and couldn't find anything. I was getting ready to replace it or at least take it all apart when I read your tip. THANK YOU! It took about three short bursts of running it before what was left of the the dime landed somewhere i could see it. I fished it out with tongs and problem solved!
    Problem Solver:
  • 9 Answers
If it were me I would remove the disposal, turn it upside down and see what comes out. Would I run it with something in it making a lot of noise? Absolutely not. If something is loose in it, it could harm the disposal.
Posted on Jan 21, 2009
I had the grinding sound, a shrilling noise. Then it jammed. I freed it with allen wrench and it started with the noise again. I checked with a flash light and found a small nail jammed inside. I was able to remove the nail. Everything works fine now. I also gave instructions, again, on keeping the drain catch in the drain at all times!
Thanks
Posted on Oct 05, 2012
Badger insinkerator, 1/3 HP does not start. Please help...i try the red button and didn't work...the blades aren't rotating....
Use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger Insinkerator Model 5-81A. I put some asparagus ends into it to dispose of them. They were ground up but water is now coming back up when I turn it on. I have lost the directions and...
yes that is right. keep turning the allen wrench untill it turns easily. then push the reset hard and try it. you dhould hear the unit run. if its running and you still have standing water, the the drain lines have plugged.
Oct 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming noise when turn on, but blade/motor not moving. Tried reset button and turn the motor with allen wrench. What else can I do?
its stuck, is it still under warranty. either the motor is bad or something is jammed in there. you need to turn the blades by hand or allen , if nothing, then the motor is somehow bad, need to replace.
Mar 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal won't drain
sounds silly but try loading it with ice and turning it on if there is debris in it the shards of ice will help to clean it
Oct 07, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Still doesn't run.
well, the impeller is slipping on the motor shaft, you need to remove the unit and see whats up
Aug 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Where is the reset button on my Badger .5 in sink erator.I think it got a small bone,in it. I stopped immediatly removed everyhting,Used the wrench so the water would go down but now it wint turn on
There is a square button on the bottom of the unit, about 1.5 inches from the center. In addition to using the allen wrench to loosen the blade, I also had to press that button to get my disposal running again.
Aug 04, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
2,697 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
