Question about Siemens C300A3 C300A-3 C300A 3 Gigaset 3 Handset Cordle
Gigaset C300 no dial tone
I recently purchased a Gigaset C300 Trio home phone system ... 3 cordless handsets! No problem setting up and plugging in - All 3 phones are functioning! However, when I connect to phone line, I am getting no dial tone? The phone line works perfectly with old phone system! Any suggestions? Thanks Chris
CORDLESSGURU
  • 106 Answers
SOURCE: line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Posted on Jan 14, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 4 Answers
SOURCE: No dial tone
It seems you can receive the calls and dial the numbers, by clicking hand free key you will hear the tone. Regarding answering machine I wonder you activate it or not for activating the machine just click the On/Off key on the base or from the main menu on the hand set choose Voice Mail section then activate Answering Machine, in this section you have other options such as Ring Delay (for choosing the delay before Ans.Mach. pick up the phone), Announcements (playing and recording announcements) and Massage Length. Reza from Iran
Posted on Oct 11, 2008
  • 9 Answers
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Posted on Dec 26, 2008
feelfemi009
  • 277 Answers
SOURCE: cordless keep searching - no dial tone - nothing...
just check the settings and apply dialling tone
Posted on Jul 10, 2009
Handset displays "Line in Use" no dialing tone and
I can't get dial tone either. Let me know if you find a solution please.
Dec 12, 2010 | Siemens Gigaset 4015 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Jan 26, 2009 | Siemens Gigaset 4200 Cordless Expansion...
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Siemens C300A3 C300A-3 C300A 3 Gigaset 3 Handset Cordle Logo
66 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
