Question about American Standard Plumbing
American standard 6008SF repair
Faucet leak repair
SOURCE: kitchen spout leaks
I had the same problem and found that the connection where the hose connects to the pull-out faucet had come loose. Pull the faucet and hose out some and tighten. The water had been leaking back down the shaft and coming out the base.
Jeff G.
Posted on Dec 13, 2008
  • 68 Answers
SOURCE: Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Posted on Dec 29, 2008
  • 6 Answers
SOURCE: leak in the faucet handle
You'll need an allen or hexkey wrench of the apropriate sixe to remove the handle from the faucet. There should be a rubber plug with the traditional red and blue colors for hot and cold. Carefully pry the plug out. There should be a hex nut in behind the plug.Remove the hex nut and the handle should come off by pulling straight upward.After that the dome shaped nut that sits below the handle should turn off counter clockwise. Beneath this is where the seals, springs, and washers are located. Good luck
Posted on May 20, 2009
  • 297 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Posted on Jul 22, 2009
My american standard model 4040 faucet is leaking at the base of the spout.
I checked online at www.plumbingwarehouse.com/american-standard-kitchen-faucet-hamilton-4040. There is a diagram that shows a seal kit that probably needs to be replaced. The diagram is really good and shows a complete breakdown of your faucet. I hope this helps.
Apr 10, 2015 | American Standard Plumbing
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Jan 01, 2010 | American Standard Kitchen Faucet 6310 020...
American standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
Jul 04, 2009 | American Standard Kitchen Faucet 6310 020...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
How to replace sprout seal kit in american standard faucet ?
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Plumbing Logo
59 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
