Question about EA - Electronic Arts The Simpsons Game for DS
Die-a-rama I get up to where you have to go through the blades on both sides of the platform in the blood room. But i can not go down the zip line to the next platform. Bart always dies and i can not hang on the line at all.
I've been having the same problem. Found the solution here.
http://www.supercheats.com/nintendods/questions/thesimpsonsgame/110474/the-simpsons-game.htm
Posted on Jan 22, 2009
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
Zip code won't print in mail merge
Make sure that you have enough layout room on your label...your zip code is probably on a seperate line, so you might need to drop down one font size, or move the zip code to the same line as your city and state ?
Nov 20, 2009 | Dymo LabelWriter 400 Thermal Printer
STUCK WORLD 4 Level 4
-Taken From GameFAQ's-
World 4-4: Six-Face Sal's Fort
Flower 1
Starting off, go right and hop across the yellow platforms. When you reach
the lava monster, wait for it to stop spewing its lava stream in the air; if
you touch it, you die. When it stops, continue to the right, hopping across
rotating platforms. Pick up the red #1 ball when you reach it, then throw it
in its slot on the wall. After the metal gate opens, continue to the right
and eat the Shy Guy. There will be three sets of yellow platforms ahead. Hop
from the first set to the higher middle set. Jump above the platforms to get
two red coins (2), then continue to the right.
To the right, you will come to a series of purple platforms attached to a
gear. Hop on the right ledges to raise the block to the right. Once it's
fully raised, jump from the highest platform on the wheel onto the block.
Shoot the winged cloud above the block to get the first Flower.
Flower 2
After you get the first flower, drop to the ground and head right into the
next room. There, go right and jump to the ledges above. In the upper-left
corner, you can reveal a hidden winged cloud containing five stars. Go
through the Middle Ring to the right, and look above to see three targets for
the numbered balls. You don't have any right now, so drop to the bottom area
and follow the coin line to the right.
At the Stork Stop, switch to Baby Mario, then continue right along the bottom
path. Make eggs from the Shy Guys that spawn from the pipe, then enter the
door to the right of it. Pick up the red #1 ball sitting there, then exit the
room. Jump onto the pipe and then to the thin ledges above it. Hop up the
ledges to reach the upper-left area. Ride the green platform upward, then run
to the right past the spike pit. At the other end, collect two red coins (4)
and the green #2 ball.
Now, quickly run back to the left as the floor rises to escape. Drop to the
area below and head directly to the right this time. When you reach the
upper-right ledge, go right and enter that room. Lower the two blocks by
turning the gears (stand on the right side of the wheels). Then, hop onto the
right block and flutter to the left one. Go left and up the first hill, then
jump onto a ledge with a Stork Stop on it.
Switch to Baby DK and hang from the ceiling to get across the spike pit to
the right. At the far right, drop to the ledge below and enter that room.
Switch to Baby Mario and run to the left, and pick up the Key. As soon as you
touch the Key, the ceiling will start to collapse, so quickly run back right
to escape. Switch back to Baby DK when you reach the door, then exit the room
and get back across the spike pit.
Now, continue up the path to the pipe at the top of the hill. Go through it,
then when you arrive in the next room, flutter onto the right ledge. Go right
and shoot an egg upward to grab the second Flower.
Flower 3
Drop off the platform to the ledge below, and go through the door there. Pass
through the Middle Ring and go right to some platforms. Hop from the yellow
ones to the ledge above. Collect the coins up there and run to the left where
you will find the next Flower.
Flower 4
From where you grabbed the previous flower, jump to the ledges above and go
left to the pipe. Go down the pipe and enter the door when you land. This
time in the room, go right and hop on the left purple platforms to turn the
gear, which will roll out a ledge below. When the gear stops turning, drop to
the ledge directly below the winged cloud. Shoot the cloud to make a red
switch fall onto the platform. Before you hit it though, go left and drop to
the area to the left of the ledge that moved. Head left and drop onto the
thin ledges, then jump to the stakes in the lava below. Jump to the right to
grab the fourth Flower.
Flower 5
Shoot the winged cloud above the left platform to get five stars. Then, jump
across the ledges and head back to the right. Hit the red switch and run to
the right along the block path, collecting two more red coins (6). At the
other side, jump up the ledges and collect the yellow #3 ball. Quickly drop
back down and wait for the blocks to disappear. Then, drop to the platform
below and collect two red coins (8) above the stake to the left. After that,
go through the door.
Back in this room, go all the way to the far left end of the room. Jump to
the ledges above and unlock the door with your Key. In that room, use the
Stork Stop and switch to Baby Mario if you don't already have him. Jump onto
the M blocks and then make your way upward along the small ledges and other M
blocks. When you reach the top, enter the door on the right side. There, jump
onto the purple platform and ride it downward along the track. When it moves
under the spikes on the low ceiling, duck to avoid getting hit by them. When
you reach the winged cloud, shoot it to reveal a Flower. Shoot a second egg
to claim it.
Boss Battle
Continue riding the platform upward along the track to the end. You will
collect two red coins (10) as you approach the top. Once you get there, go
down the pipe. Fall into the next room and land on the ledge below to find
two more red coins (12), then jump to collect the Character Coin to the right
with Baby Mario. To the left of the coin is a hidden winged cloud you can
jump and reveal; shoot an egg at it to get five stars. When you're done, go
through the door at the bottom to exit.
When you appear in the main room again, grab the two red coins (14) to the
left. Then, run to the right and jump to the upper-right ledge. Go right and
look up at the colored targets, and throw each number ball at the appropriate
target. Doing this will raise a block to the right, so go ahead and enter
that new room. Ride the platform on the track to the right, collecting four
more red coins (18) along the way. At the end of the track, go through the
door to reach a new room.
Use the Stork Stop and switch to Baby Mario if you don't already have him,
then start running to the right. As the ceiling blocks start to fall, keep
running and collecting the coins. One row of coins towards the end will be in
the air, so you will have to quickly jump to get them, including the last two
red coins (20). At the end, go through the Middle Ring, then open the red
door. In the boss room, go up the hill and bounce to the area above, where
you will meet Six-Face Sal.
The boss consists of six faces on a giant wheel which hangs on the top screen
above you. The bottom half consists of a long platform of donut blocks which
sink if you stand on them for too long, and four purple platforms which turn
the gear when you jump on the sides. The battle will start off with one of
the heads coming out and dropping spiked balls onto you. To attack, turn the
wheel by hopping on the platforms, then when the head you want to attack is
at the bottom end of the giant wheel, shoot an egg up at it.
After the first hit, there will now be multiple heads popping out to attack.
Some heads will be red, but only one will have a pale, light color to it.
That's the one you should be looking to attack. After several rounds of this,
at one point having all the heads attacking you at once, the battle will end
after you attack successfully several times.
Oct 24, 2009 | Nintendo Yoshi''s Island 2 for DS
How do I get the third star coin, world 8, 1st Castle
You only get one shot at it. if you die and you cross half way point, you are going to have to start another level and exit out of it, in order to start from the begging again. After crossing all of the fire stuff and what not and getting to the third platform, where the second walking dead turtle is. is where the fun and your skills will be put to the test. hit the red square just above you until the "brown" moving platforms on your far right (not the one that is right below you) is on top. There is three places where it could be. just make sure that is on top. Get on it. if you stay on the far left, you'll get the second coin, no problem. jump onto the fourth platform. and DO NOT hit the red square. There should be a "brown" platform on the bottom. If there isn't you have to restart, your game. you did something wrong. After this you know the drill and you'll end up on the fifth platform. Where there'll be a coin and a bonus and the midway point. if you die past this point. You'll have to restart the entire level. Get to the Big doors and this time the "brown" platform that you need will be waiting for you. Make sure you duck right away otherwise you'll get knocked down. The rest is up to you. Once again Don't DIE! good luck.
Mar 30, 2009 | Nintendo New Super Mario Bros. for DS
EA - Electronic Arts The Simpsons Game for DS Logo
101 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
