Question about VIA P4MA Motherboard
I lost my motherboard guide book of p4m266-8233
Now i my PC doesn't play sounds.and i want to know the method to connect my PC housing sound jacks to the motherboard.
system model- p4m266-8233
BIOS-phoenix award BIOS v6.00pg
  • 4 Answers
Madhrchod find it your self.
Posted on Jan 20, 2009
How to connect 5.1 speakers to ps with asus p5gc motherboard
So you want to connect your Play-Station to 5.1 surround sound speakers through a motherboard, so you can get sound from the Play-Station through the speakers while playing on your LCD TV (LED is something completely different)
You need to get a very specific type of Sound Card to do that.
I would recommend the Creative Sound-Blaster X-FI it is relativity old now, so it will be quite cheap you could get it for about 60 pounds. It is a PCIE card and comes with an external connection box and External Creative X-FI USB sound card dongle thingy.
I would recommend some bettor speakers for this as well as you get 3D crystal sound automatically, unless you turn the settings off. There are options in the EQ for just about every music type and every environment you can think off. Best of all it comes with a remote control. The sound from the Play-Station goes in to the connection box and the sound out from the conection box goes to the TV. There are 6 Audio in 9 audio out on the connection box and a bunch of other connection ports for various things. MIDI, small jack connectors large jack connectors, I-pod connector wireless expansion port, Ethernet port, Fiber optic ports x2, component audio, scart and a bunch that I don't eaven know what they do. ,
Sep 21, 2013 | ASUS Computers & Internet
No sound from speakers
You don't mention the sound card(s) in the PC nor the method of connecting to the monitor. Some video cards have HDMI connections for audio and video out to a monitor and will not allow any other audio outputs to work. Regardless of sound source interface, check to be sure that the audio source is the one that is NOT part of your video card and is NOT set to output DIGITAL audio signals.
Once this is done, select the the "add-on" or "expansion slot" sound card (if it is the type that plus into a slot on your motherboard) or the "built-in to the motherboard" type (if the jacks are soldered directly to the motherboard) as the DEFAULT or ENABLED. Set to ANALOG output - NOT digital if a choice is offered. Connect the speakers. This should be via cable terminated with a stereo mini jack - NOT a special digital optical or coaxial cable / connector. Most modern PCs will have several mini-stereo jacks from which to choose - nearly all use the GREEN ringed jack for the FRONT (or main) left & right stereo speakers. Regardless, if yours has GREEN jack, you should use it - if none have a color code, look for markings that indicate either "speakers" ,"output", "front" or "L & R". If there are no indications, check your manual. Set your volume level on the lower side, play an audio source and adjust speaker volume and / or audio mixer settings in the system tray as needed.
Only one sound card will work in a PC. Make sure that all connections are made to the ENABLED card, otherwise no sounds will be heard. Digital output is primarily targeted to facilitate connections to external amplifier and speaker system - most often like those found in a Home Theater PC setting - or a monitor / TV connected by an HDMI cable.
I hope this helps & good luck!
Jun 04, 2013 | Microsoft Windows 7 Home Premium 64BIT...
I have a samsung galaxy and the headphone jack doesn't work it only plays it over the speaker phone on the phone it does not play it over a radio with a jack for everyone to hear and I also tried the...
If it's a Cell Phone you should post to Cell Phone category for a Cell expert. Usually the headphone jack has been damaged due to pulling on the cord causing a broken connection.
Apr 27, 2013 | Computers & Internet
How can Install Bh 200 headset driver for ProBook 6550b
actually you don't need any driver for headset,you can just plug it and the sound will play.but if it doesn't make any sound,make sure that you connect it to the right port or jack,and you've installed the sound driver,if you haven't,you can download your sound driver here
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=4173772&lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=4173845
please let me know if it's working or not and thanks for using fixya
Aug 29, 2012 | HP Computers & Internet
My headphone jack is not working at all. I just purchased it today, the sound card is saying no errors, the sound plays fine out of the speakers and the headphone do work Im using them on my cell now
Take it to the Service center. need to replace the headphone output connector's. these will happen from Moistor,Dirt block or Dry solder in the Laptop Motherboard. best of luck. ( Try, put headphone jack in and out for 20 to 30 times, or check the sound comes out via headphone, when pressing the connected jack.) best of luck
Feb 01, 2011 | Sony VAIO VPCEA36FM/W Laptop
Hi my compaqSG1018IL model of desktop motherboard cd has lost so how can i got sound after formatting
if u cant install the sound driver just buy a USB sound adaptor and connect it to the USB port and connect the speaker sound jack to the sound port in that....u will have sounddb8ba00.jpg
Feb 02, 2010 | Computers & Internet
Desktop sound card
i believe you have something connected wrg since your pc only requires one jack from sound card. to you subwoofer then its seperated to he others. read the book on *********** board to see if you can change your options on the sound configuration.
Nov 28, 2008 | Logitech X-530 Computer Speakers
IPod MA146LL/A no sound
You should check and see if the headphone jack is broke or not. That sometimes accounts for the reason why sound won't come out.
Go here to see about replacing/fixing a broken headphone jack:
http://store.ifixipodsfast.com/ipod-parts-/-installation/ipod-video/ipod-video-headphone-jack-/-hold-switch/prod_69.html
May 10, 2008 | Apple iPod MA446LL/A MP3 Player
SL-75KAV
Here ya go http://www.motherboards.org/files/manuals/118/75kav.pdf
This has all the pictures you will need to reconnect everything. If this helps be sure to rate my help.
Jan 22, 2008 | Computers & Internet
VIA P4MA Motherboard Logo
1,137 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
