Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Soap all ran out onto the carpet
We put the soap in the soap thing and within seconds all the soap emptied onto the carpet in a puddle.
  • Official Brand Answer
  • 315 Answers
Hey, sorry to hear you'r having difficulty with your ProHeat.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1060&cid=ccsocial
Posted on Jan 07, 2013
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: the carpet does not look like it is clean
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dhgjdg
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a bissell proheat
heatman101
vx
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Don't know how to use with shampoo
Best to not put shampoo in machine. Put traffic lane cleaner in sprayer with hot water, spray onto carpet after thorough vacuuming, allow cleaner to dwell 5 to 10 minutes and clean and rinse with fresh clean water in machine. For best results do NOT put shampoo in he machine even though it was designed for it. Most of the machines brought in for repairs are clogged with soap gunk. Carpets will be cleaner and stay clean longer because the soap has been rinsed out of carpet
Sep 26, 2013 | Vacuums
Hi, each time i turn on the vacuum cleaner, the water in the tank will bubble and foam causing an overflow although the water level is just right. i will have to throw out the water and refill again....
Try changing the water before you turn it on the first time -- that will probably help you resolve the issue. It seems like there is probably some sort of soap or carpet shampoo in the system causing your foam issue. If your carpets have been shampooed or if you have spilled soap or detergent on your carpet at any point, the vacuum is probably picking up remnants of the soap when you are cleaning, and it is working its way into the water supply of the vacuum. This will continue to happen until you have completely removed the soap from your carpet -- and if you haven't cleaned out your vacuum very well. Try rinsing out the hoses and water tank really well, to make sure that the soap is not stuck in the vacuum itself and give it a try. Hopefully just rinsing out the machine will fix the problem.
May 29, 2011 | Rainbow Vacuums
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
77 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
