I have a kelvinator split system aircon...model number KSR25D and it doesn't seem to be cooling as it should...help
The cooling system is not as cool as it should be...could it be that it needs re-gasing?
hotuna
  • 288 Answers
SOURCE: loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Posted on Dec 28, 2007
  • 23 Answers
SOURCE: i have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Posted on Jun 15, 2009
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
SOURCE: Split system getting cold at first then just not cooling the room
Split Air Conditioners are not meant to run constantly. so check this first . you may have a faulty component i.e. compressor, condenser, evaporator, or evap fan. Depending on your technician you may have gotten ripped off. You need to find out if he checked the system for refrigerant (gas) leaks. A good way to tell if your ac is leaking is feel the low and high side copper pipe in between the inside and outside units.
the smaller pipe (high side) should be hot be carefull maybe touch it with an ice cube. The Large pipe should be cold but not iced over.
if there is ice on any component you should call a qualified tech. you probably have a leak. you should also clean your air filters which are right above the vents. I am a certified AC mechanic and i have seen this problem. in Iraq because of ambient temperatures being high the systems take alot of abuse and we dont fix them because repair costs exceed replacement costs alot of the time. good luck.
Posted on Nov 19, 2009
I have a kelvinator single split wall mounted air conditioner that is no longer cooling. Everything seems to working ok but the air it is blowing is not cold. Can you advise what this may be.
not cooling indicates that the compressor is not working
most problems are from the outside unit from vermin infestation across the program board ( ants , lizards roaches etc)
best advice is to get a kelvinator service man out to determine the exact cause of the problem
Jan 27, 2017 | The Computers & Internet
I have a kelvinator Electrolux split air con model r51k/bge it doesn't seem to keep coolits set on 17 and the control says cool the fan says high but no cold air comes out wat could be the pro
many reasons could be there, check that the outdoor fan working or not if yes my be the compressors is tripping, if no, check the volt for outdoor, check the gas and the leakage
Nov 21, 2014 | Electrolux Heating & Cooling
I am in a rented unit, the power went off the other day and now I can't get my aircon split system (no manuals provided) to work again
Normally in your situation I would call the owner and ask for instructions. You could request the owner to send a technician and get it up as a tenant you cannot be denied use of the aircon if that is part of your lease benefit.
We cannot help you much at fixya.com without knowing the make and model number of the aircon unit. Usually with split systems I could suggest you turn the mains power off at the circuit breaker, wait a few seconds and then turn back on. Then go to the internal unit and with remote control start the unit. See if everything comes back to normal.
Sep 02, 2014 | Heating & Cooling
My aircon is not blowing
Most liekly needs to have freeon added to the system, if that doesn't help its propely a problem with the electric motor on the blower.
Nov 07, 2012 | Gree 9000 Btu 23 Seer Ductless Mini Split...
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
I have a sanyo aircon split system and i need to know the icons
Jun 11, 2009 | Sanyo Split System Air Conditioner
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
