Question about Maytag Washing Machines
Where is water level switch located
Just keeps running
    Sergeant:
  • 291 Answers
Usually in the control panel. If you go to www.searspartsdirect.com you can type in your full model# and usually get exploded views and corresponding parts list. Look for "pressure switch." My experience is that pressure switches seldom need replaced usuall trouble is found in hose or where hose connects to tub.
Posted on Jan 06, 2013
3 Suggested Answers
  • 104 Answers
SOURCE: hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Posted on Jan 28, 2010
  • 385 Answers
SOURCE: We have a Kenmore 90
The ppart you are looking for is called the water presure switch and it is located inside the control panel.It will have a small plastic hose going to it. Hope this helped.
Posted on Jun 03, 2011
Hi i have a simpson esprit and I can't stop the
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
Jun 12, 2011 | Washing Machines
We have a Kenmore 90 Series washer and the water level function has stopped working and the water does not shut off - it just keeping running - therefore the wash cycle does not begin b/c it just keeps...
Jun 03, 2011 | Kenmore Washing Machines
My amana front load washer just keeps filling. It is running out of the soap fill area. It is giving me code OE. Suggestions on what that means?
Thanks for choosing FixYa and welcome. If the water keeps running, you need to check your water level switch. It may be defective. This switch controls the water level in the machine.
May 02, 2011 | Washing Machines
Pump noise in rear of car keeps running / Gas pump or load leveller / seems longer run time olately in cold weather ( 1999 olds aurora)
you might have a leak in the rear suspension load leveler. check connections with soapy water. locate where sound is coming from. fuel pump in tank is a slight hum and not that noticable, but the air comp for load leveler is. Also spray around rubber boots on shocks, also check load leveler switch on axle to frame for broken or loose lever control.
Jan 21, 2011 | 1999 Oldsmobile Aurora
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
Top loader keeps filling up with water and floods no matter what the cycle programmed in
HI. This will be a defective water pressure switch. Use the procedure below to inspect this switch for faults. Replace the switch, if needed.
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
The switch location will be just behind the main control sector, or near the inlet valve. It will be the only switch with a small hose running into its housing.
Dec 26, 2009 | Fisher and Paykel Washing Machines
Wate does not shut off
If your saying , when the machine is off , the water keeps running , you need to replace the water mixing valve pt. # 285805 . If your saying , when filling , the water does not cut off , then it could be the water level switch hose came off , which is located behind the control panel , and it just needs slid back on , OR , it could be a bad water level switch ( not likely though ) .
Nov 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Over running water fill
You have a bad water level selecter switch (Load size) you will need to replace. It's not hard, located inside the console and does not cost much.
Oct 09, 2009 | Kenmore Washing Machines
Washer fills with water and runs over. water doesn't shut off at level settings. what could cause this problem?
HI, there is a water level switch that monitors the water level in your unit. this switch has failed. replacing this switch will fix this issue.
It is located inside the washer near the water valve assembly.
Jun 18, 2009 | Washing Machines
Washer overflowing
Remove the control console cover. Find the water level switch.
It has a small tube attached to it.
Remove the tube and blow air through it. It is probably stopped up. Reattach it to the water level switch.
Look over the length of the tube and may sure it is not pinched.
Set the washer to spin and run spin for about 1 minute.
Then run water on a lower level and see if it shuts off.
If not replace the water level switch.
Apr 18, 2009 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
