Question about liftmaster Tac-1 Telephone Entry Access Control Tac1
Gates do not open from remote phone
I have wired the tac1 for no telco, checked wiring starting at the tac1 unit, to the dmark, to the house box and to the wall plug.Being wired for relay 1 the *9 command from the phone should activate the relay but it does not??
2 Suggested Answers
swolfinor
  • 504 Answers
SOURCE: My wall mounted opener/closer has stopped working.
REMOVE THE UNIT FROM THE WALL AND DISCONNECT THE WIRES.
GO TO THE BACK OF THE POWERHEAD AND CONNECT IT DIRECT WITH SHORT WIRES (POLARITY IS IMPORTANT HERE) TO TEST IF THE UNIT NOW WORKS. IF IT WORKS REPLACE THE EXISTING WIRES - THEY MAY BE SMASHED WITHIN THE WALL OR UNDER A STAPLE THAT IS TOO TIGHT.
IF THE ABOVE TEST DOES NOT WORK REPLACE THE WALL CONTROL UNIT.
HOPE THIS HELPS
Posted on Nov 28, 2010
Why does the gate open on its own during the day with nobody home?
If the gate uses a remote control, someone may be cruising the neighborhood with one of the same type trying to find a house to burglarize.
May 30, 2015 | Home Fencing
Why no dial tone. Only static?
If that happens on all phones and you have copper wiring inside and out it usually is caused by a high resistance open (bad wire connection) either inside or outside the house.. If it happens on only one phone it is either ther phone itself (swap with another phone to prove it's the phone) or the wiring to the phone has a loose connection or is bad. If it happens one all phones test it where the telephone connection comes into the house. If it is still noisy the call the local TELCO. Wet lines can also cause the same problem so if you suspect there was any water leaks in the house disconnect the inside wiring from the telephone entrance connection before testing other if the problem is inside TELCO will charge. If you using a wireless phone use a wired phone to do the testing.
Aug 26, 2014 | Lands Phones
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Miracle one gate opener not working. Was work fine and lately not opening all the time. Now not at all. Looked and all fuses they are ok. System on light is off. only ligts on in control box are the...
Have you checked the fuses? They are small and can be difficult to see because of the thin wires. Check those first, especially the motor fuse on the lower left corner of the board.
Does you system use a wireless remote or keypad, or to open/close.
Jan 06, 2014 | Chamberlain Elite Miracle One Swing Gate...
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the...
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
May 14, 2011 | liftmaster Chamberlain Garage Door Opener...
The prior owner of my house had verizon fios, the fios wiring is in basement as well as junction box for telephone (gray box) I have unplugged the ac power plug to the fios as I am not using their service....
you're better off calling verizon to remove it.
but no, it uses your power ... not anything from the street. fiber optic cable is made of glass and does not conduct electricity.
Jan 22, 2011 | Lands Phones
My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Apr 14, 2010 | Uniden DECT 6.0 Cordless Telephone...
Static
If the static appears on both sets, the problem could be with the phone line itsself. If you live in a detached house you could check the line at the network interface device (NID). Its a gray box about 8" x 6"give or take and should be marked as such. (it's usually over by the electric meter.
With a screw driver open the NID, there should be a little cord and a plug that it plugs in to. Unplug the plug and plug your telephone into it if the static is still there its a problem with the line and the local telco will need to be notified. If the static disapears then its an inside wiring problem.
If you live in an apartment or condominium complex it would probibly be easier to call your telco provider and let them troubleshoot it.
Hope that helps
Mar 27, 2009 | Uniden Cordless Phone
Westinghouse Security System
Download the manual. I can't remember if it is in the User's Manual or the Programming Manual but a sequence to reset the security code is detailed in one of them. Also, it soulds like the telephone line was wired through the system for full seizure. To defeat this, you will need to take it out of the phone lines at the outside telco box. How it is wired is that the alarm panel intercepts the telephone line first and then feeds the circuit back out to the main junction where the telco comes into the house.
Sep 07, 2007 | GE Security Simon 3 Wireless Home Security...
liftmaster Tac-1 Telephone Entry Access Control Tac1 Logo
19 people viewed this question
Top liftmaster Home Security Experts
Lawrence Oravetz
Are you a liftmaster Home Security Expert? Answer questions, earn points and help others
