Question about Gateway Computers & Internet
My 2004 mazda rx8 got flooded and was trying to un flooded noticed that the motor wasnt turning , starter was spining but ring gear got lose from fly wheel
  • Gateway Master
  • 32,281 Answers
If the ring gear is not fixed to the flywheel then the flywheel need to be removed from the engine then heat up the ring gear to place onto the flywheel to shrink fit it back onto the flywheel.
If the ring gear/fly wheel is damaged or the flywheel face is scored then it maybe better to get a replacement (new or 2nd hand).
Posted on Jan 07, 2013
2002 mazda 626 new starter wont engage flywheel. it sounds like starter is spining wont engage flywheel
Couple possibilities. Was the starter just replaced? If so. Were their any shims (small metal pieces) that were not put back? They space the starter so the bendix and gear can align with fly wheel.. secondly could be a bad starter, broke bendix. Bad gear..or third missing teeth on either fly wheel or starter..
Oct 28, 2017 | Mazda Cars & Trucks
When turning the engine over rx8 wont fire
Search google for "flooded rx8 fix"
Jul 12, 2014 | 2004 Mazda RX-8
How do i unlock the security system for my 2004 mazda rx8
hola tengo un problema con mi mazda rx8 la luz de sistema de segurida esta predida y no puedo encender el carro que puedo hacer??
Jul 21, 2012 | 2004 Mazda RX-8
2004 Mazda RX8 won't start
You already were told by a mechanic what your
cars issues were
Most likely you need a need timing belt or some
sort of engine work
Jul 04, 2012 | 2004 Mazda RX-8
Have a 95 chev s10 with 2.2 and standard trans. intermiten won't start when it dosen't start I can hear the starter spining but it dosent engage with the motor,already replaced starter and selenoid and...
Was the starter shimmied to match up with the fly wheel properly so the starter gear fly wheel ring gear don't bind or out to far apart that they don't reach each other. The other problem is that if the starter gear was to far apart, it may have shaved the teeth on the starter gear causing your engine not to turn.
Feb 25, 2010 | 1995 Chevrolet S-10 CA Edition
Engine rolls over does not start
I had this problem. Twice! It sounded like it wanted to turn over but couldn't. Your engine may be flooded. I had to have mine towed to the mazda dealer (if under 100,000 miles it is under warrenty) so they could fix it. The second time they had to replace my engine because of a bad compression ring.
Jan 30, 2010 | 2004 Mazda RX-8
Rx8 car has trouble starting you need to step on the gas 7-10 times for the car to start
The RX8 has always been a bit problematic at starting, at least until Mazda started fitted uprated starters (~2006). The standard, weak starter motor spins the engine quite slowly, causing problems getting compression to start the engine.
There's various things to try...
DON'T pump the gas whilst starting - foot OFF the accelarator (might be beneficial to depress the clutch just to reduce the loading on the starter motor). Check all the RX8 owners' forums - standard advice.
DO use a confident turn of the key - keep cranking until it catches (but not for more than 10 seconds - in which case leave for 10 seconds before trying again) - don't just crank for a second or two, then retry. That's as per owner's manual.
DO ensure that you leave the engine to warm up ALWAYS before shutting off - to avoid fuel being left in the rotor - that affects compression badly if left any period of time, resulting in very poor starting (risk of flooding).
If non of the above helps, get a hot-engine compression check to ensure that the engine isn't shot. If the engine is okay, then consider getting an uprated starter motor, or 3rd-party replacement. Many 2004/2005s have had their starters replaced (I considered mine, although I've had no problem over winter :)
Jan 07, 2010 | 2004 Mazda RX-8
My 2004 mazada rx8 won't start, smells like its flooding out! turns over good. Pulled in one night -no problem. Went to get in and go next day and wouldn't start!
HI check your air filter make sure is clean, replace spark plugs if fault whit fuel ,if thats the case also replace your oil and filter
Sep 23, 2009 | 2004 Mazda RX-8
Starter cranks over but engine will not and not start
this is common,it is flooded,Mazda has a concern with this model and a dealer may install a new motor if the compression is down
Mar 29, 2009 | 2004 Mazda RX-8
04 RX8 won't start??
Hold the gas pedal to the floor and try starting the rx8 has anti flood technology that gives less fuel when gas pedal is to the floor I do it all the time hope this helps
Mar 07, 2009 | 2004 Mazda RX-8
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
