Question about Mach Speed Trio DROID-7C Android 2.3 Tablet
I fell asleep with my android, i got it locked up cause it thought i was trying to put it in when i was sleeping so it tells me to sign in with my gmail account i do but it just errors? I can sign on
Trio android media player 4.3" 4.0 Touch Internet Tablet
    Master:
  • 193 Answers
I sat in my kindle (in the car) and bent it, now all the data is unreadable. Can it be fixed?
I doubt it. Go back to place you bought it. Best buy or amazon may be able to help you replace it without loss of anything you have stored on it. Try amazon first.
May 10, 2016 | Amazon Kindle
Why won't it turn on?
battery is dead needs recharged .
Dec 17, 2015 | Tagital Tablets & eReaders
My RCA tablet model#RCT6293w23 locked out of tablet due to a virus/scam cannot access anything on tablet how do Ifactory reset when I can't use the settings or access any part of the tablet
You must then do a factory reset using the Power and Volume
Buttons.
Here is a good link that tells and shows how to do it:
http://www.rcatablets.com/how-completely-reset-your-rca-rct6103w46-android-422-tablet
The model number is not the same but it should work anyhow.
There is a typo in Step 1, however so do this instead:
With the tablet turned OFF (not sleep but OFF) press and hold down at the same time both the Volume(-) button and the Power button. Continue to hold both of them down until you get a screen with the Android Robot, and or green text. That should set you up to follow the instructions.
Good luck.
Jun 02, 2015 | Tablets & eReaders
I just bought a andriod tablet from someone and i dont know the pattern lock or the email account how do i unlock it?
if its legitimate and not stolen just ask the person you bought it from for password or reset to factory settings and put your own pattern lock and email on it
Nov 05, 2014 | Tablets & eReaders
How do i unlock the tablet
Try different unlock patterns. Once it rejects you it will ask you to sign in to your google account. Type "null" in the user name line and "0000" for the password. I was locked out of my android phone and used this to get past the unlock pattern and back in to my phone.
Nov 04, 2014 | Hannspree 10.1" Android Tablet Grey Tablet...
I locked my android device and dot remember the combination
Since you did not tell us the name of it just go on google and type in the name of the tablet and after it put hard reset.
EX-samsung galaxy tab hard reset. you should be able to find method. sounds like the android system stoped responding
Jan 30, 2014 | Tablets & eReaders
Take the password off cause I forgot it
If you remember your gmail you can unlock it like that. all you have to do is try your password for about 5 times until it says you have to wait 30 seconds to try your password again then look down where it says forgot password? press on that and it will take you to a screen that tells you to put in you gmail and if you put it in correctly and pressed sign in it will unlock your phone and you also get to choose what kind of password you want
Jan 08, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
Acer tablet a700 manual
SO sorry to hear this. I have seen to many tablets go BRICK after they are left to charge and then either they stay on the android boot/battery screen or they stick on the logo screen. There is a few things u can try to rescue you tablet.
First is this a acer tablet a700 or is it a acer iconia a 700?
I will assume its the tablet since if it was the iconia phone you would of been more upset for the 300 dollars plus. SO here we go and by no means can i tell u the exact reason these tablets fail or brick after charging.
This is a upper end tablet and not the cheap china clone. so hear is your first thing to try.
DO a hard reset with the keys first. WARNING reset can wipe out all ur data and set it back to factory if thats what u had it set to do. So if u have a sd micro card in its slot.. remove it and disconnect it from the computer dongle too. There are several diff options in recovery settings..back to factory or restore you settings from a backup file.. or wipe it and start all over.
so be aware that by doing a hard reset u can end up reinstalling everything u had on there.
Factory reset is first done with keys. HOLD THE POWER BUTTON AND THE SOUND UP but make sure you have the sleep / lock button right. at same time until it powers off..if not try power/sound up..this is the most common android tablet reset.
If this fails, then
The right side of the tablet is home to a microSD card slot (under a plastic flap) and a micro-HDMI port. The power/sleep/unlock key and 3.5mm headphone jack are located along the left edge, while a volume rocker and orientation lock switch are found on the top edge of the tablet, .
The micro-USB charging and syncing port, as well as a pair of speakers and a reset button, are located at the bottom of the A700
If u have made sure u have the sleep /lock switch in correct position. U have only one option left..the dreaded reset button. its on botton next to the usb sync charge port. Use a paper clip NO SHARP OR POINTS that break off.ie PENCIL lead .
DIsconnect from power and remove any micro/usb bridges..hold it in until it powers on and off..then cross your fingers and push the power button and wait.
If this fails to reset it back to factory and revive it. There are some software tools..SDK ANDROID isnt for the weak at heart though..lots of info and things that you will pull ur hair out trying.
If the reset above doesnt work..and u made sure its not in lock/sleep.. u are best off contacting the help line first and then last.
good luck my friend..
I will follow ur case..so post what happens and i will get it
Oct 20, 2013 | Tablets & eReaders
Mach Speed Trio DROID-7C Android 2.3 Tablet Logo
122 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Brett Duxbury
Brett Duxbury
Lawrence Oravetz
 Grubhead
Grubhead
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
