Question about Canon PowerShot SD10 / IXUS I Digital Camera
Canon Ixus-I 4.0 Meg
I can capture a photo, after clicking the button, my preview photos are distorted, when I hit playback, still I have distorted image, I have "Vertical Lines" on my photos. I Went to Canon Service Center, asking me $200 for the optical lens replacement and labor, I rather get a new one for that price, but I still want my Old Ixus-I to work.
They said it was the optical having problem, when i used video, no problem previewing the video. It must be capacitors also, burnt due to heat maybe?
Posted on Jul 31, 2007
    Genius:
  • 2,985 Answers
When they go wrong - they stay wrong I am afraid as you discovered - repair prices are out of this world - simply get the next one.
Posted on Jun 29, 2007
SOURCE:
Photo transfer to pc
Transfer Photos from iPhone to MacIn almost all cases, the fastest and simplest way to copy pictures from an iPhone to a Mac is with Image Capture and Preview. We'll discuss how with both apps:
Using Image Capture to Import Photos in OS XThis is a fast and efficient way to pull photos off the iPhone, which treats the device as a digital camera:
  • Open Image Capture from the /Applications/ directory (or through Launchpad)
  • Connect the iPhone to the Mac through USB
  • Select a folder from the menu (default is Pictures folder) and then click "Import All"
  • OR: Select individual photos, and click "Import" to only copy those pictures over
You can also transfer pictures to your Mac with iPhoto or Preview, which is just as simple and actually has a virtually identical interface for initiating the transfer. Here is how to import with Preview:
Copying Photos with PreviewThough Preview is usually thought of as an image viewer, it can also serve as a fast importer:
  • Plug your iPhone into your Mac
  • Launch Preview
  • From the File menu navigate down and select "Import from iPhone..."
  • Select "Import All" to get all the pictures, otherwise individually select pictures and click 'Import'
  • Look in your ~/Pictures/ folder for the photos from your iPhone
Optionally: Click the checkbox with "Delete after import" if you want to delete the photos after they have been copied over to the computer.
The benefit of using either Preview or Image Capture is that these apps are on virtually every version of OS X since from the very beginning of the OS, so you won't find a Mac version without them. iPhoto on the other hand is generally limited to the consumer model Macs, thus making it not always available on pro models, but it does work as well, and iPhoto will also serve as a photo manager of sorts.
Transfer Photos from iPhone to PC (XP)Using Windows Plug & PlayThis utilizes the pop-up that shows by default in Windows when a device is connected to the computer by way of USB.
  • Plugin your iPhone to the computer without iTunes running
  • Wait for a popup asking you what you want to do with the device
  • Select "View Content"
  • Find your photos through the folders that are displayed
  • Copy the images from Windows as usual
Note that in Windows 7 and Windows 8 you will often find the iPhone mounted under "Portable Devices" but it can also be found listed under "Digital Camera". Opening either will work to copy the pictures over, but typically Digital Camera opens directly to the DCIM directory whereas Portable Devices will sometimes require minor navigation within the folder to copy the files.
Using iPhone as Digital Camera in Windows ExplorerIf your iPhone is already plugged into the PC, you can also try this method:
  • Open "My Computer"
  • Find the iPhone, it will appear as any other camera would
  • Open iPhone to find your Photos
  • Select the pictures you want to copy to your computer and copy/paste them into the desired location on your PC
The Windows approach treats the iPhone more like a file system, just like it does with standard digital cameras that are connected to a PC. That generally makes Windows even easier for moving pictures back and forth if you like to cut & paste things directly from one folder to another in My Pictures or My Documents. Nonetheless, you can also use your favorite photo importing application to pull the pictures from the device as well.
Remember, if the iPhone pictures are not showing up in Windows, make sure the iPhone is unlocked first. Otherwise the iPhone will be found in 'My Computer' but all of the content on it will be invisible and inaccessible. If you run into that, all you need to do is touch the iPhone, unlock the screen and enter the passcode, and all of your stuff will be visible as expected.
Finally, you can also sync your photos using just iTunes on either Mac OS or Windows but that is more for iPhone backup purposes and doesn't really serve as a means of accessing individual pictures.
On a Windows PC the easiest way to get pictures from your iPhone is to just use Windows Explorer, but there are two ways to go about this. In either case, unlock the iPhone before beginning, or else the photos may not be visible.
Jul 19, 2013 | Cell Phones
Tip
Review iDisksoft Photo Recovery for Mac : easily recover deleted photo and files
Have you lost precious photos or video files? Did you accidentally delete a photo or a group of photos from your digital camera? Did you perhaps unplug a USB or other storage media while it was in the middle of music files transfer? Do you wish there is an easy way to recover your these files? Thanks to iDisksoft Photo Recovery program for your Mac, recovering lost or deleted photos on your computer system is not as hard as you might think. It is indeed a common misconception among people that pictures, photos, and images once get lost, deleted, and formatted they will be lost forever. Actually, when files and folders are deleted, they are not removed from the storage media. The only thing that gets removed is the file location information from the file tree. These photos are still stored on your Mac machine or digital media memory card, etc. As long as the pictures are not overwritten, it is definitely possible to recover pictures, photos, and images on Mac with <a href="http://www.idisksoft.com/photo-recovery-for-mac.html">photo recovery for Mac</a>.<br /><br /><a href="http://www.idisksoft.com/photo-recovery-for-mac.html">iDisksoft Photo Recovery</a> for Mac is able to thoroughly scan the information on your storage media and find the files that have lost their location information to trace the lost and deleted photos, audios and videos. It is a professional, reliable, and cost-effective Mac photo recovery software, which is special designed for Mac OS users to recover lost photos, videos and music files due to accidental deleting, formatting, software crash, virus-inflection, power failure, improper operation, and other unknown reasons from Mac, based iPod (except iPod Touch), USB drive, digital camera and other storage media. Preview thumbnail lets Mac users preview lost photos, evaluate recovery quality in advance, and recover the photos they really want. With easy-to-use interface, Mac users even a novice user can enjoy <a href="http://www.idisksoft.com/photo-recovery-for-mac.html">Mac photo recovery</a><a href="http://www.idisksoft.com/photo-recovery-for-mac.html"></a> at great ease just by a few mouse clicks.<br />You just need three easy steps to perform recovery on your own: Select, Preview and Recover. After running it in your PC, you should click "Photo Recovery" button. And then, select the target storage device where you want to recover your images, video and audio files and click "Next" button to start automatic scanning. You can preview the recoverable photos in the preview window below and select the ones you want to recover. Finally, select a recovery path to save the recoverable photos<br /><img src="yangwang74.jpg" /><br /><span style="font-weight: bold;">Key Features of iDisksoft Photo Recovery for Mac</span><br style="font-weight: bold;" /><br /><span style="font-weight: bold;">a.Various File Types Supported</span><br />iDisksoft Photo Recovery for Mac will retrieve most image file extensions including JPG, JPEG, TIF, TIFF, GIF, BMP, NFF, CD5, PNG, PGM, PNM, and so on. The program also supports audio and video files as well which is a huge help since many digital cameras now include video and audio recording features.<br /><span style="font-weight: bold;">b.Easy to Use</span><br />Downloading and installing iDisksoft Photo Recovery is quick and easy, there is just a few mouse clicks to <a href="http://www.idisksoft.com/photo-recovery-for-mac.html">recover photo on Mac</a> at great ease and you shouldn't have any problem here. It's a relatively small installation file that should not take too long to download. The interface is very easy to use and will be intuitive for anyone familiar with Mac systems.<br /><span style="font-weight: bold;">c.Powerful Recovery Ability</span><br />Recover photos both from Mac computers and storage media such as hard drive, iPod, USB storage, flash card, etc. while most Mac photo recovery software on current market can only recover photos from media storage. This means that you can recover photos from virtually any type of storage media.<br /><span style="font-weight: bold;">d.Versatile Preview Ability</span><br />Preview thumbnail allows you preview images and camera RAW files before Mac photo recovery to let users evaluate recovery quality in advance. You can preview the recoverable images in the preview window above the list column, or double click the image to preview it in a large window.<br />It also provides users a real-time and direct scan results by showing the recoverable photos during the scan process to let uses stop scan once the target photos are found.<br /><span style="font-weight: bold;">e.Precise Mac Photo Recovery</span><br />Recover deleted photos from Mac with original file names, shooting date, and storage paths.<br />If you're looking for an easy-to-use, intuitive tool to help you recover photos and other media that you might have deleted, then this is the best program for you. It's very easy to use, and by downloading the free trial version you will be able to see if this tool can help you recover your photos. But if you want to recover comprehensive Mac data files from lost, deleted, logical corrupted and formatted hard drive, it's recommend that <a href="http://www.idisksoft.com/data-recovery-for-mac.html">iDisksoft Data Recovery for Mac</a> is the best choice for you.<br /><br />
on May 12, 2011 | Prosoft Data Backup 2.0 (databackup2) for...
Nikon d40 motnior blank while taking picture.
That's entirely correct. Live view cannot work on SLR's whilst the photo is being taken due to the requirement for the mirror and live view sensor to flip out of the way during image capture.
Live view on SLR cameras is a misleading description, it's really a live preview instead.
Dec 11, 2009 | Nikon D40 Digital Camera
Lexmark 2600 scanning to MAC-no can do
Edward, I have this same problem. Were you able to solve it? Anyone, can you help? I have installed the drivers. When I connect the printer to my Mac, it launches ImageCapture and previews the scan fine. But I am unable to get the "scan" button to become active, adn there is no place to save the scan. If I click "save pdf to iphoto" it saves a pdf of the entire screen, rather than just the photo. Appears not to be Mac compatible for scanning purposes. Thank you for your help.
Jul 12, 2009 | Lexmark X2600 InkJet Printer
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Black screen, not capturing photos
have the same problem...
it happened about a month ago and i pressed the display button and it worked, but now that doesn't work either!
Jul 22, 2008 | Canon PowerShot SD1000 Digital Camera
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Canon PowerShot SD10 / IXUS I Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
