What does E11 error code in Electra washing - Washing Machines
    Sergeant:
  • 291 Answers
Need full model # to answer.
Posted on Jan 06, 2013
  • B.H. Countryman Jan 08, 2013
    I cannot find any info on your machine. Can you give me some details? Does the machine have power? Did it stop midway through a cycle, and where in cycle? Is there water in tub and is door locked? Have you recently (or ever) performed any maintenance on the machine; for example, cleaned the pump filter or screens on inlet watervalve? Let me know, i may still be able to help. Thanks.
3 Suggested Answers
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
  • 141 Answers
SOURCE: FAFW3577KWO washer-code E11
Your machine may have short circuit with the inlet valve since you are facing problem after 5 to 6 mins you are suppose to change the inlet valve
Posted on Dec 24, 2009
Hi,What does it mean e11 in the washing machine of the type electra?
It is an error code. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 12, 2015 | Washing Machines
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Oct 05, 2013 | Frigidaire GLTF2940ES Front Load Washer
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
Error code e11
if its a frigidaire front load washer then code e11 indicates thats its a slow fill water problem,remove your hot and cold inlet water hoses and check the hose screens for blockage
May 31, 2012 | Washing Machines
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
My Frigidaire washer is reading error code E11..how do I resolve this problem?
E11 = Long Fill Time
Check to see the water valves are opened all the way. Check water hose screens for buildup.
Jan 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
