Question about Minolta magicolor 2300W Laser Printer
MAGIC COLOUR 2300DL SHOWING CODE OBH,OEH AND O8H
On powering the printer it gives you this codes. is their a mode in this machine to reset the code?>
pleease help
  • Minolta Master
  • 6,680 Answers
VENT FAN 0BH, SUCTION FAN FOR THE FUSER (Hot Part) 0EH, MAIN MOTOR 08H, three motor going bad at once ????? mite have a main board fault, or the printer has been in a very dirty area, for the two fans, main motor not in use for a long time, or something is jammes
Posted on Nov 19, 2015
Hi, Fisher and Paykel washing machine code 49 and harness was loose. Fixed it, checked solenoids etc so should be all OK but code still showing. How do you clear the code after fixing the problem?
You don't. There is no magic reset button. Clear the fault & it resets itself. If fault is still showing then there is still a problem, Either faulty cold water inlet valve, bad connection or more likely a faulty main control board. That last one is the usual reason for that fault.
Sep 26, 2017 | Fisher and Paykel Washing Machines
I HAVE COPY MACHINE SHARP AR-5320E DISPLAY ERRO H2 AND NO FUNCTION PLEASE I WANT TO KNOW WHATS PROBLEM AND HOW CAN I REST CODE 14
You have a heat issue. Go into service mode select code reset 14 and execute. Turn power off and on. Now if you don't know how to enter service mode. You need a qualified tech. You tap version twice that will give another screen select sim 14 and execute.
Nov 19, 2014 | Sharp Office Equipment & Supplies
Fs1020 has aproblem code e0001
A E0001is a fuser error code. You may have had a power surge and the copier got confussed and coded out. You will need to reset the error code in service mode. If it can not be cleared, you may have a problem with the fuser unit
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Jun 14, 2014 | Epson Expression XP-305 Inkjet...
Error code e0000002-0000
You have a fuser fault - you can reset the code in service mode - then turn the m/c off and on again - to see how to reset the error code look through my solutions and you will see where i have explained how to 'clear errors' on an IR machine.
Dec 15, 2009 | Canon imageRUNNER 2200
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Machine Error 8460N Laser Printer
To get the machine error code
Get into maint mode
Within 2 seconds hit:
menu,*,2,8,6,4
This will put you in maint mode.
Press 82
This will give you the machine error code.
Press stop/exit
press 99 to exit maint mode.
Let us know what the machine error is.
Jan 16, 2009 | Brother MFC-8460N Laser Printer
Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Dec 23, 2008 | Office Equipment & Supplies
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Error code SC 544
Relates to fuser unit. Needs to be reset from service mode.
Mar 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Minolta magicolor 2300W Laser Printer Logo
104 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
