Question about iRiver PMC-120 Digital Media Player
PMC 120 problems
Well the I river PMC 120 was working well for the first few hours I used it. I went to use it in the truck and now all I get is a white screen when I plug the adapter in. Both batteries were charged and working. Now nothing works. I tried to reset the unit but nothing worked. Any Ideas???? Things to note: To reset, all I did was push the button, not sure if there are more steps to resetting the system. The only function is the white screen when the adapter is plugged in. Wont shut off! Computer no longer acknowledges unit when hooked up via USB.
  • 594 Answers
Is the adapter the correct one, maybe wrong voltage (5.0) or wrong phasing (ring is -, tip is +)
Posted on Feb 09, 2008
SOURCE:
My laptop does the "found new hardware, mtp device" popup, but doesn't recognize it as iRiver
Here's the link for the user manual if you need it; http://www.iriveramerica.com/download/pmc/PMC-100.pdf check page 137 of the pdf and try the restore to original settings. do you have the setup cd? - it has troubleshooting for the unit, which is not available on the website there are no drivers available, it uses windows media player as a driver, but the manual and the support site; http://www.iriveramerica.com/support/multi/pmc100_faq.aspx both claim that you need windows media player 10, not 11 to synchronise. you can download it from this link; http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx or install it from the setup cd just uninstall wmp11 first. many of this type of unit and mp3 players etc have problems with wmp 11, hopefully reverting to 10 will allow you to sync Hope this helps :)
Jun 27, 2007 | iRiver PMC-120 Digital Media Player
How can i get this iriver pmc-120(20GB)Digital media player
Ebay have them at around $300-350 +p&p.
http://cgi.ebay.co.uk/iRiver-PMC-120-20-GB-5000-Songs-MP3-Player_W0QQitemZ9709194994QQihZ001QQcategoryZ114622QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
http://cgi.ebay.co.uk/iRiver-PMC-120-MP3-Player-20GB-widescreen-MP4-PMC120_W0QQitemZ120206957789QQihZ002QQcategoryZ114622QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
Hope this helps,
erch.
Mar 15, 2008 | Televison & Video
Greatful if you can help me
i have a pmc with bad logic board. I want a logic board to fix mine. But I can sell u my screen.
Dec 09, 2007 | iRiver PMC-120 Digital Media Player
Need a driver for the pmc 120 for XP.....
You need to use windows media converter (under the windows media folder) and convert all videos to WMV format and you have to use 320X240 output resolution, 800kbps sound quality. Anything else will result in a format out of specification error. Now where to move those video files is a mystery as there is no video folder. You can move all pictures into the pic library, etc. Windows Media Player 10 is designed to natively pick this device up and make synchronizing easy. when I plugged my Ebay PMC-120 in, Windows media player tried to sync all media files to my device, pictures, music, windows sound effects, etc. Should not be an big deal if you have the correct USB cable, mine came with one. Iriver.com has the software, but you have to go into the update software area of the site and there is a link to the master program in a set of upgrade instructions, no other place that I looked. Not Vista compatible unless you download the installation program and set its compatability to winXP BEFORE you run it. And stick with WMP 10 as it was around when this device was made.
Nov 19, 2007 | iRiver PMC-120 Digital Media Player
Iriver pmp 120
i could help you repair this email me at [email protected] i had the same problem i fixed it my self
Mar 19, 2007 | iRiver PMC-120 Digital Media Player
Casing replacement
I have one with a broken screen i can sell you. [email protected]
Jan 29, 2007 | iRiver PMC-120 Digital Media Player
Will not turn on
Howdy! Same thing happens to me after only a while of having it. iRiver were of very little help but I found my solstice in selling it to some other unfortunate person. I found if you charge it for a hour and then take out the charger, remove the battery and replace it, it will go. What a pain! Perhaps the battery drains out when it sits unused for a few days.
Sep 17, 2006 | iRiver PMC-120 Digital Media Player
Recovery tool
You're getting the first and second screen, but the third screen that shows those tools when it's fixing a disk error doesn't come up? It either didn't find anything wrong, or it did and couldn't fix it. You should get in touch with the company. SG
Jun 26, 2006 | iRiver PMC-120 Digital Media Player
Open Questions:
pmc 120 when i set up a sync list on media player and start to sync it to the pmc, it works sometimes, other times it aborts. it gives me the message "you can now disconnect iriver Portable media centre" when i try to do it again it tell me Windows Media Player encountered a problem while synchronizing the file to the device. For additional assistance, click Web Help. when i go to th web help it explains the problem as You've encountered error message C00D1236 while using Windows Media Player. The following information might help you troubleshoot the issue. Cannot sync the file Windows Media Player encountered a problem while synchronizing the file to the portable device. Because this error can occur for a variety of reasons, there is no single solution. To resolve the problem, try disconnecting and resetting the device. See your device owner's manual for specific instructions on performing this procedure. In some cases, this error can occur if you try to sync a hidden file to a device. To resolve this problem, either remove the file from the sync list or change the file's properties so that the file is not hidden. Also the error details are Technical Details This error might have been triggered by an error in another program or component of Windows. The following information describes the original error. Original Error Code Original Error Message C00D1179Windows Media Player does not detect a portable device. Connect your portable device, and then try again. So im not sure why it keeps aborting. if you can tell me your views on this please do. Other information that may be useful i tried formatting the unit : 1. Through windows media player 2. through explorer the pmc is supposed to be used with windows media player 10. i had wmp 11 originally and it didnt really work too well. i rolled back to 10 and it worked better but still not consistantly. i tried installing wmp11 again and now the Pmc120 will abort after about 3 songs of an album i would have setup to sync. thanks for your help. Gavan Doran. Ireland.
Oct 16, 2007 | iRiver PMC-120 Digital Media Player
iRiver PMC-120 Digital Media Player Logo
122 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
