Question about Cisco DDR2201 Residential Gateway - Wireless router - DSL - 4-po
Connect blackberry 9300 to cisco ddr2201 router
I try to connect my blackberry 9300 device to my home wireless signal with no success. Other mobile devices connect properly. my BB connects without problems in other wifi signals both residential and public.
  • 28 Answers
Change the radio band from n/a/g to mixed so that any device can connect to it.
Posted on Nov 07, 2013
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
prakas_3p
  • 107 Answers
SOURCE: Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
  • 91 Answers
SOURCE: We just bought a Cisco Linksys E2000 router. We
You may need to update the drivers for the adapters that you have on the desktop.
Posted on Sep 15, 2010
puertobori
  • 7733 Answers
SOURCE: Using Cisco Router E1000. Wireless laptop will not
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
a-2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
b-Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
1)To change the router's SSID or the wireless network's name, click here.
2)To change the router's channel, click here.
3)To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
I think is better to configure your router again, so you can set the router to keep alive every time.
Posted on Nov 07, 2010
I need the address ip for configure?
Open command prompt. Type netstat -rn.
The IP address under "Gateway" for either the "default" line or the address 0.0.0.0 would be the gateway IP address of the router and likely the address used to configure it.
For example:
Internet:
Destination Gateway
default 192.168.2.1
Jun 08, 2014 | Cisco DDR2201 Residential Gateway -...
Router set up
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Oct 23, 2012 | Cisco DDR2201 Residential Gateway -...
I am having problems extending wifi range
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Sep 16, 2012 | Cisco Re1000 Linksys Wireless And Range...
I have the Linksys Valet M10.
1. Many wireless routers are using the same wirelesschannel. Many manufacturers choose channel 6 as the default.2. Analogue video senders used to send audio and video toother TVs in the home.3. Microwave ovens emit interference in the 2.4GHz band.4. Wireless speakers and console controllers can causeinterference with the wireless router.5. Bluetooth devices, newer Bluetooth devices can jump todifferent frequencies if there is a connection problem.6. Power cables located near the wireless router can causedrop outs and speed reduction.7. Fish tanks will cause massive Wi-Fi shadow on the otherside of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflectwireless signal away your computer.9. Building materials will block wireless signals such asplasterboards with metal foil, reinforced concrete walls and floors. Alsoobjects near the wireless router such as metal filing cabinets and otherelectrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performanceby 25% when it is close to the wireless router.
Mar 18, 2012 | Linksys Valet by Cisco M10 Valet 4 Port...
Intermitttant connection with router cisco e2000 , have checked everything that I can think of , am I the only one
A lot of factors can cause routers to drop signals. There could be too much interference so your device keeps changing channels. Try changing your wireless settings from auto channel to one of the available channels in the list. You can get to the router config at http://192.168.1.1
If your devices stay connected to the wireless but the internet cuts out, it may be your ISP modem.
There might also be a firmware update for your device that fixes this issue as well.
The latest is version 1.0.04 build 7. Here is the link:Download
Regards, Chris
Jul 02, 2011 | Cisco Linksys E2000 Advanced WirelessN...
We purchased two Acer netbooks in the same household in bedrooms across the hall in the same house. We purchased a linksys -cisco wireless n home router. Sometimes one gets a signal and the other...
Often times something unseen can be blocking the signal, such as heavy material (brick walls or bathroom piping). Try moving around the room and seeing if the signal is still poor.
Feb 28, 2011 | Cisco Linksys E2000 Advanced WirelessN...
I am trying to connect using Cisco VPN through my Motorola wireless router, but cannot connect. I check with my internet service provider and they do allow VPN. Our IT division has checked the...
The devices appear to be in functioning order. However, the connection network requires another computer on which signals are directed towards. The computer server on which network resources are acquirable is unavailable. For example, your devices can provide sevices to another computer if any were avialble. Usually an internet provider would allow acess to several computer with subscription. Consult an internet service provider, examples, at & t, T- mobile, Verizon, boost mobile, or consult any available at your local area. www.at&t.com, www.t-mobile.com, www.verizon.com, Goodluck
Jan 11, 2011 | Arris SURFboard SBG900 Wireless Router...
Excellent Wireless signal but limited or no connectivity
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 30, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless fails to operate sometimes on Amilo Pi1505 laptop. Have tried switching wireless on and off without success. After a couple of days it will suddenly start operating again without imput from me.
It may be a compatibility issue betwen the mobile device and the router. Find the router model/name as well as the mobile card or built in mobile device manufacturer/model name so that I may research this further. Some settings in My Network Places will allow you to change how your mobile device will act. For example, you can change the settings so that it ONLY looks for the specific network in your home, rathe than searching for the strongest signal which may cause you to lose connection while it looks around. Another factor to consider is location location location. Where is your router in relation to the laptop at the times that you are losing signal? Consider how many walls it has to go through, or floors if its upstairs and you are downstairs.. Try changing some of those settings and find out those model names, then get back to me to let me know how things go and we will go from there. Good Luck!
Apr 17, 2008 | Computers & Internet
Cisco DDR2201 Residential Gateway - Wireless router - DSL - 4-po Logo
96 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
