Question about HP W2007 20.1 Widescreen Monitor
Set HP w2007 to factory standards
Pictures and icons look fuzzy and blurred. How can I set the monitor back to factory standard appearance? I have already downloaded the correct driver from the HP website without changing the corrupted appearance. Help.
  • HP Master
  • 3,904 Answers
Go into control panel. When you are in control panel click on Personalize. When that comes up go to display. Under that tab you can make the adjustments to the screen resolution that you would like. There should be an option to alllow windows to select the optimal resolution for you.
Posted on Jan 07, 2013
I have Nikon Coolpix s9500 and in almost all mode I have blurred picture. What is wrong in my camera?
Is there any mode you have a picture that is ok? Are the pictures blurred on the monitor screen, or also on the computer?
Do you shoot with the focus assist to auto?
Are you shooting in dark areas, without vibration reduction?
Did you try motion detection.
As you can see lots of questions.
Try to put the camera in the factory settings and start over again taking pictures. Please describe as correct as possible what you get and what you don't get. And how you did use the camera.
Hope this helps a bit.
Oct 28, 2013 | Cameras
How do you remove the blur warning icon from the camera screen. Thanks
Welcome To FixYa.
Blur warning ussually appears in Suppressed flash mode. In this mode the flash does not fire even when the subjects is poorly lit. Blur warning will appear in the monitor at slow shutter speeds to warn that pictures may be blurred. Use of a tripod is recommended.
To view or hide other indicators on the screen/monitor you just have to click the DISP/BACK button.
I hope this information will help you on your issues regarding your camera.
Feel free to send us comments and suggestion if this information is helpful.
Thank you for using FixYa.
Apr 06, 2011 | FUJIFILM FinePix Z35 Digital Camera
HP w1907 monitor has fuzzy text
Procedures of acquiring high definition pixel quality
1.power on the computer wait until the desktop of icons display after booting has been completed
2. using the arrow of the mouse or pointer to an area on the desktop without icons, right click to display a prompt list
3. locate the appearance and setting prompt on the list.
4. a click to provide the options to increase the picture quality termed pixels
5. LCD monitors could produce several thousand pixels, select a choice nearly approapiate for reasons explained
a. the highest selection of picture quality provided on the list for a monitor powered by a separate computer with extremely dense graphics like known for modern gaming could cause monitor to blank out as precaution.
b. when selecting a picture quality from the list provided on the appearance settings area after a right click on the desktop, be sure about the compartibility of the monitor and computer unit, explained
c. most modern retail provide system units with higest definition pixel capabilites for several funcitons as gaming graphic and design, connect such a unit to an old monitor would display low quality definition pictures. However, that could be fixed by adjusting the appearance setting only with caution not to select the most highest available from the list of pixels.
Dec 06, 2010 | HP w1907 LCD Monitor
My screen resolution is not like it's supposed to be.
The native resolution of you monitor is 1440x900. If you previously had it set at a lower resolution (say 1280 x 720) the text would appear larger than it does now. You can change the appearance of internet explorer by using the Zoom function (Ctrl +).
Jul 05, 2009 | Gateway FPD2275W LCD Monitor
Fuzzy pictures
It's possible that some of the settings are set improperly on the camera. Try resetting the camera back to factory default settings and see if this makes any difference. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to RESET - press Ok - highlight Yes and press Ok. This will set the camera back to factory settings. Try to take some images and see if they are still fuzzy.
Mar 29, 2009 | Olympus Stylus 700 / 700 Digital Camera
Picture focus problems
make sure there is no flower icon on bottom left corner of screen-very common on sony to hit macro button to turn on by accident and you will get blur-only for extreme closeup-hit flower button to turn off if on and let me know if that was the problem
May 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
When Zooming picture it produces blurred or fuzzy picture
This is when zooming through your camera LCD I presume? For small screens usually banding and pixelation is common, if this happens also when the picture is zoomed in on a larger monitor like on your computer then the resolution you set for your camera is low. You can check for the camera setting and increase the resolution from for example 1024x768 to a much higher value and the fuzinnes (blur) will disappear altogether...
Feb 08, 2008 | Fuji FinePix F460 Digital Camera
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
HP W2007 20.1 Widescreen Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
