Question about LG WT4801CW White 3.7 Cu.Ft. Large Capacity High Efficiency Top Load Washer with Electronic Control
LG wt4801cw stopped working with 30 minutes left . I unplugged it and now it won't poer on. Do you think it is the control board?
  • 4 Answers
Lid won't open! Mine too! Wet clothes, waiting for parts, if you remove the sliver back cover, about 16'X16's four Philips screws, look up on the right side of the machine behind the drum, way up there's a solenoid. Mine had a red string! I pulled on it and got my wife to try the lid, it opened! LG says you cannot open it, but that's not true. They just don't want you looking inside the junk machines they sell! Good luck!
Posted on Sep 05, 2014
    Sergeant:
  • 291 Answers
It's possible, but it could be other things. Did you check the service breaker? If it is tripped no power will go to the machine. A tripped breaker would indicate either a breaker that needs replaced, is not of sufficient amperage to run the machine, or even a short in the machine.
Posted on Jan 06, 2013
  • 7 more comments
  • Sally Orsini Jan 06, 2013
    Yes, I checked the breaker, it wasn't tripped but I turned it off and on again for good measure. Lamp works in power outlet too.
  • B.H. Countryman Jan 06, 2013
    Was there power to the machine before you unplugged? Did it shut down with control panel reading 30 min? I'm not an expert on your machine but 30 min remaining sounds like it must have shut down soon after starting.
    There is a thermal overload protection circuit in the motor that may have tripped. It should reset itself after motor cools sufficiently. Could take thirty minutes or more. If that is problem it might restart after a time, but will likely trip again. Is it possible it's an extra heavy load?
    There was power to the machine before i unplugged it. I unplugged it because it was frozen at 30 minutes. So I unplugged it and now it appears there is no power but there is power. I tried unplugging and holding down the start button for 5 seconds and plugging in again with no luck. It's been down for three days. Managed to get the clothes out that we're locked inside. There wasn't a heavy load in at the time. The machine is only 13 months old.:(
    I am thinking it is control board or display board. When I open the control boad and plug in there is no LED light on.
    Is the machine in the garage perhaps? Apparently it doesn't like cold temperatures and will not power on when it's too cold.
  • Sally Orsini Jan 07, 2013
    The washer is inside our home. It is not cold.
  • B.H. Countryman Jan 07, 2013
    Again, i'm no expert with your machine, but seems if there was any power at all going to the board the LED would be on. Try this, unplug the machine, check the wiring harness and all connections going to the board. Reseat the plastic connectors on the board itself. If you see a green ground wire make sure it's tight and not sitting on rust. Give a tug on any wires that disappear to other parts of the machine. When you are satisfied you've checked them all, plug it back in and see what happens.
  • Jim Lutz Oct 15, 2013
    Sally - What was the resolution - I am going through the same thing
I've got a LG Intellowasher WD-1023C and it spins real slowly or not at all and there is a glow from the bottom, it also stops with 9 minutes left on the 30 minute wash
a glow does not sound good. any error codes. glowing sounds like a hot/shorted wire, maybe the heating element. i think i would unplug and call for professional service.
Oct 25, 2016 | LG Washing Machines
My RCA 46la45rq tv remote AND side buttons stopped working
The panel control circuit inside should be checked. Contact any experienced service technician.
Nov 27, 2012 | RCA 46 46LA45RQ LCD TV
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have LG lmhm2017st microwave and some times the buttons won't work but now it inputs 11:11 start all by it self over and over again . If I leave it unplugged for a few minutes it will start to work...
If you have warranty use it asp, from the description the problem is in the keypad "membrane shorting" or the microprocessor control board is becoming intermittent, it will get to the point and stop functioning.
Mar 20, 2012 | LG Microwave Ovens
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
I cleaned my refrigerator out the next day it stopped working
unplug the fridge and plug it back in after a couple of minutes. this will reset the control board located behind the fridge. if after plugging it back in, it doesn't work, then you need to have the board replaced.
Jul 16, 2011 | LG LFC20760ST Stainless Steel Bottom...
Water turned off unexpectedly now machine won't spin final cycle and timer stays on 4 min and appears to continually try and drain ( intello 7.5
Unplug unit for 5 minutes to reset control board. If problem still persists, you will need to call a technician to service it.
Jun 15, 2011 | LG WM-2277HW Front Load Washer
LG washer WM2455H The start button does not work,
Unplug the washer for 5 minutes to see if the commands for the cycle will reset. Also try pressing the stop button for ten seconds.
Dec 04, 2010 | LG WM2455 Front Load Washer
LG WT4801CW White 3.7 Cu.Ft. Large Capacity High Efficiency Top Load Washer with Electronic Control Logo
246 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
