Question about Bruder MAN TGA Container Service Truck
I have a man with a falt code tcu 3117-00 wot dose this mean
Tcu 3117 man
RE: MAN TCU DIAGNOSIS 03117-00 tcu code 3117 means clutch self adjustment which is between 3 common brothers( pressure plate..release bearing and clutch ) but before you decide to change any check the pressure system from the air drier valve into the actuator if its ok
concerning the pressure leakage around the gearbox indicates there is a problem with the zf astronic...sometime even the automatic transmission fluid may also leak its the zf astronic replace or repair if necessary
in addition actuator problem will come up with tcu fault code 3198-08 on the screen
Apr 12, 2017 | Miscellaneous
Man TGA 440 falt code 03300-06
I can't answer your question about Dolls, Playsets & Toy Figures "Man TGA 440 falt code 03300-06" because simply, I can't understand whay do you mean.
Please reformulate your question, so maybe someone else might help you
May 04, 2015 | Toys
Hi i a toyota camry azura 03 when i drive my car it winds in 3rd gear wot dose that mean
so what engine, ?
what trans, manual stick or auto?, none of this we can guess.
is winds, whines?
wot, = wide open throttle or what?
please re post.
do post symptoms, fully, is this a funny sound, or trans slip.
or what, use the word, odd sounds or like that. if yes.
Dec 26, 2014 | 2003 Toyota Camry
What dose falt coad 92 mean
What model and year please?
Oct 27, 2014 | Cars & Trucks
2000 hyundai accent with error codes p0717 and p1529
P0717 - Input/Turbine Speed Sensor "A" Circuit No Signal
P1529 - Customer Snap Shot Request
  • NOTE_P1529 is a generic code which is issued by the TCU to tell the ECU to turn on the CEL. It means nothing by itself and is usually included with other TCU codes.
Aug 21, 2010 | 2000 Hyundai Accent
My washer is say f-o5 wot dose that mean
an f05 error message means that the pressure switch is jammed on empty or as already said a problem with pump.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=4791&start=0&postdays=0&postorder=asc&highlight=
See above.
Aug 11, 2010 | Hotpoint Washing Machines
1989 dodge datona 2.2 turbo coge 13
hello i got a 1990 dodge daytona shelby the code 13 is MAP sensor signal to the computer (ECU) not changing so the map sensor is should be on the firewall with a vacuum line on it little black box looking thing well make sure it plug in and good and that it dose not have a leaking vacuum line if that dose not work you have a bad map sensor thay run about 30 to 100 at auto zone o onec you think you fix it remove the battery term for about 5 mins with the key on and trun the key off before conttecting the battey back up drive for about 20 mins to see if the code show up if you get code 55 all that means is end of falt code list you mite get a code 12 meaning The battery has been disconnected and the computer (ECU) has been reset hope that help keep that daytona runing it a good car
Oct 07, 2009 | 1989 Dodge Daytona
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
Bruder MAN TGA  Container Service Truck Logo
988 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
