Question about Sony Playstation 3 (PS3) Console
I took apart my ps3 and now it has no video or sound
I took the top off of my ps3 and removed the long 7 screws and blew out the dust and reassembled it and now i have no video of sound how r u dorinn
    Scholar:
  • 27 Answers
Try doing a video mode reset. When the power light is red, hold your finger on the power button. keep holding it after it turns green. It should then beep and reset...
You can also try a fan test to blow out your system. this works much better than using an air compressor. To do this, turn off the power switch on the back of your console, hold your finger on the eject button, then flip the power switch on the back of the system to the "on" position. When the fan comes on release the eject button. The fan should then go into overdrive and run hard for about 20-30 seconds. Keep in mind, if your system is pretty dirty this is going to blow dust all over everything around it,
so do it away from other electronics! Good luck...
Retrohack
Posted on Jan 20, 2009
  • 51 Answers
Unfortunately, you will have to open it up and look yourself. Your warranty is now void so Sony will not replace or repair it for you.
My PS3 does not turn on ,..the yellow and red light blinks
You've got the YLOD.
Here's a DIY tutorial on how to fix but I recommend getting it fixed by Sony direct!
Oct 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not start-the green light and hard drive starts up for a few seconds then shuts off
The problem is a hardware problem, which is due to a failure in a component it the unit.
You will have to dismantle the playstation, clean it and couple it back together. To dismantle the playstation, follow the steps below:
1.
  • Pull the warranty sticker off of the bottom of the PS3. This will void your warranty, so make sure that the problem you are addressing is not covered by your warranty. Note that taking your PS3 to be repaired by someone other than Sony will still void your warranty. You are not losing anything by taking apart your PS3 yourself. Under the sticker will be a small piece of rubber that hides a single screw. Remove the rubber piece and unscrew the screw.
  • 2 Slide the faceplate off of the PlayStation 3. After the faceplate is removed, you can now separate the two halves of the plastic covering. Remove and set aside the top piece of the plastic case to expose the internal components of the PS3. On the underside of the top plastic covering, there will be a memory card slot at the bottom-right corner.
  • 3 Locate and remove the Bluetooth circuit board. Remove the four screws to lift the Bluetooth board free. This is located at the bottom-left corner of the main body of the PS3 if you have the system flat on its side instead of standing up straight. This will look like a green rectangle with a tan metal covering.
  • 4 Locate the small circuit board that controls the power and eject functions of the PlayStation 3. Remove the four Phillips-head screws in order to separate this piece from the body of the system. This is located at the bottom-right corner of the PS3, directly in front of the disc box.
  • 5 Locate and remove the Blu-Ray/PS3 player. This is the large tan metal box that is located in the top right corner of the PS3. Unscrew the player and flip it upside down to expose the circuit board that controls it. If you want to remove the circuit board, there are five small screws that hold it in place.
  • 6 Remove the power supply from the inside of the gaming system. This is located at the top-left corner inside the PS3. To remove this component, there will be two telephone-like plugs that have to be unplugged, one at the top and one at the bottom of the power supply. Additionally, there will be 13 screws that hold the power supply in place. The back and front plastic coverings of the PS3's shell will now easily slide free.
  • 7 Remove the final internal component, which is the PS3's motherboard. In order to do this, remove the metal covering the rests on top of the motherboard. There will be 11 screws that border the metal covering as well as four screws in the very center, two from each of the rectangular center pieces. Once the screws are removed, the metal covering will lift off and the motherboard will be able to be removed.
  • Have it cleaned and properly reverse the process to reassemble it back together.
    Note: If you are still under the warranty period of purchase, you can take it back to the dealer that supplied it to you for their technical support.
    Take care and good luck
    The system is not reading any games
    Hello there,
    The reason your system is not reading any game is because the lens is not working, to fix this, follow the steps below;
    1. Unplug the power cable, video cable and controllers and remove any discs from the disc drive
    2. Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
    3. Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
    4. Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard
    5. Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
    6. Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
    7. Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
    8. Replace with new laser module, reverse your steps and reassemble the PS3.
    Take care
  • Step 2 Remove the rubber foot on the left side of the PS3, unscrew the security screw and slide off the top lid.
  • Step 3 Unscrew all nine screws under the lid and lift off this section to reveal the inside. Be sure to unplug the cable that connects to this lid before completely removing it.
  • Step 4 Remove the gray box. This is the Blu-ray drive. Disconnect the power supply and the cable connecting it to the motherboard.
  • Step 5 Remove the five screws on the outside of the Blu-ray drive to remove the metal shell.
  • Step 6 Remove the next set of screws on the black plastic cover to gain access to the inside of the Blu-ray drive. Disconnect the red and black cable to pull the two plastic halves apart.
  • Step 7 Remove the cables and brackets and screws holding the laser in place and slide off the laser module. Be sure to check the model number on the laser to make sure you purchase the right replacement model.
  • Step 8 Replace with new laser module, reverse your steps and reassemble the PS3.
  • Read more: How to Repair a PS3 That Does Not Read a Disc | eHow.com http://www.ehow.com/how_5778475_repair-ps3-not-read-disc.html#ixzz0sQmwqziZ
    Jul 01, 2010 | Sony Playstation 3 (PS3) Console
    PS3 Playstation 3 Disassembly, Forgot to Remove disc.
    its not the drive thinking there is a cd in there. when you re assembled it the motor that draws the disc in would have moved slightly so it thinks it pulls the disc in when it hasnt actually reached the end. take it apart and ensure it is retracted completley befor carefully re assembling. good luck
    Jan 13, 2010 | Sony Playstation 3 (PS3) Console
    I took my dvd apart to get some coins out & now it's unresponsive
    I am guessing you had a disc in the drive when you took it apart (or maybe the coins had something to do with it).
    What you need to do is disassemble the Bluray drive again. With the top cover off of the Bluray drive, power on the PS3, then hit the eject button. The plastic guides should snap into the right position and then you can reassemble and it will work again.
    Sep 26, 2009 | Sony Playstation 3 (PS3) Console
    Trying to open Gateway desktop keyboard
    I wouldn't. I would **** debris out with a vaccum.
    May 24, 2009 | Gateway 2520915 Keyboard
    PS3 won't take disc
    when reassembling bluray player you must take care to activate the side tracks (blackbars) back and forth , there should be very little play in the mechanism! there is also an aluminum wing towards the back underside of the blu ray drive. the wings have nipples at the tips that slide in the blackbars. finally put the top lid on, but dont screw it on tight yet. insert a dvd and then tighten the 5 black screws after smooth enrollment. hope this helps. if you like we can do it for you for $30
    Nov 12, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Iron
    Iron
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
