Question about Garden
Stihl 009l bolt stud replacement part number - Garden
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
Dolfoff
  • 148 Answers
SOURCE: How would I replace the bar hold down stud bolt in
At our dealership we replace the Bar studs with Heli-Coil and locktite for $20.
NOTE: Remove the old stud by double-nutting and screwing out of the case and marking the end that came out. Take it with you to NAPA and get the correct Heli-Coil size and a small tube of BLUE Loctite. (Might be cheaper to let the Stihl dealer do it)
Hope this helps!
Posted on Sep 28, 2009
  • 5603 Answers
SOURCE: I need to replace the bar bolt on a stihl 011 at
If the bolt is still viable, you could try using two nuts back to back as a jam nut and wrench it out.
If it is not viable (damaged threads) try vise grips. You MIGHT try a bit of heat from a Bernz torch as last resort, and of course penetrating oil like PB Blaster.
Posted on Apr 13, 2010
  • 41 Answers
SOURCE: is the bar bolt on a stihl o11 chainsaw a bolt
threaded stud...
wireguy212
  • 1627 Answers
SOURCE: I have a stihl 009L chainsaw the stop button
Check to see if the ground to the switch is okay,if it is replace the switch,if not replace the wire or wire end.
Posted on Oct 06, 2010
How do you replace the fuel lines on a Stihl chainsaw electronic quick stop 009L?
Hey Doug,
Replacing the fuel line is a pain.. not hard.. just time consuming and requires some disassembly.. TAKE PICTURES OF ALL PHASES OF DISASSEMBLY....From the Stihl's I worked on, you have to remove the air filter, the carburetor, most of the covers.. when you get to the fuel tank.. just remove the line with needle nose pliers..reinstall everything according to the pictures... Good luck..
Aug 30, 2017 | Stihl Garden
No spark on my stihl 009L
disconnect ground from coil and try for spark again. If you get spark now then you have a short in your ground wire if no spark still replace coil
Oct 11, 2014 | Stihl Garden
On a Stihl 009l chainsaw how do u change the stud
If my Memory service me well. After removing the bar cover & bar.
Use the two nuts that hold the bar on to lock them together on the end of the bolt, then you should be able to unscrew the bolts from the housing. Replace the new bolts in the same manner. I hope this is of some help.
Oct 09, 2014 | Garden
How does the gasket kit go on a stihl 009l model311y go
You need to strip the carb step by step take a photo of the striped down carb showing diaphragm and gasket positions re-build is reverse of strip down.make sure all carb parts are extreme clean before you commence re-build good luck.
Jul 17, 2014 | Stihl 009l/010/011 Brake Handle Solid...
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
Saw is cutting the wood on an angle
the cutters on your chain are not filed evenly. Either take saw to a Stihl dealer and have chain sharpened or get a new chain. Ask them to show you how to sharpen your chain.
Apr 23, 2014 | Stihl 009l
I can't get my stihl chainsaw trigger throttle and trigger interlock to catch so I can start it. I pressed them both at same time but does not catch.
Release the interlock button first, then the trigger throttle. If this does not work, replace the interlock button.
Oct 23, 2013 | Stihl 009l
I need a parts diagram for stihl 009l chainsaw
Stihl does not have a parts list anywhere,they have it where you have to go to them for anything,spark plugs is one thing you don't buy from them,6.95 versus 2.95 at Autozone,ngk .
Dec 11, 2012 | Garden
How would I replace the bar hold down stud bolt in my Stihl MS 310 chain saw? Thanks.
Hope this helps!
Sep 27, 2009 | Garden
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
