Technika 40-270 keeps switching off after 5 seconds
After switshing on, the TV keeps going into stand-by after 5 seconds, then it tries to come on again by itself, then switches to stand-by again, this keeps repeating until TV is powered off.
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
  • 47 Answers
SOURCE: My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Posted on Jun 22, 2009
dsacco86
  • 1077 Answers
SOURCE: 42 LG plasma no picture but sound. found internal
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other parts inside from being damaged. Most likely the TV has a power supply related problem. The common part to go bad for flat panel screens circuit board that powers the screen itself. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. Best thing to do, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. Its the best repair guide material for fixing TVs. And most cases the new part cost less than $15 by searching on the internet with the part number.
2. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
Technika tv
reset the Tv, disconnect the power cord from the outlet wait by 45 seconds, and try again.
However if the problem persist, you must test the power switch from TV for open or faulty, test the sensor tv, try to turn ON directly from Tv, NOT FROM R.CONTROL. If the problem persist, you must go inside from the power supply for faulty.
God bless you
Jul 29, 2013 | Televison & Video
I brought this remote and it doesnt have a code for my technika tv do you have an answer?
For Technika, pls try following code:
1171 1231 1261 0012 0432
or alternately, please try the magic search code as follows: 1. Turn On your device (LCD TV) 2. Press device mode (TV) from your URC (universal remote control) 3. Hold (P+ or Ch+) and (Vol -) on URC at the same time for two seconds until indicator lights up 4. Enter "magic search" code - press device code (TV), then press (P+ or Ch+) and (Vol -) on URC, and enter device (TV) magic code # 0001 5. Press device mode (TV), same or repeat process # 2 6. Hold (P+ or Ch+) and (Vol -) on URC at the same time for two seconds until indicator lights up and your URC is ready to start searching. 7. Aim the URC at your device (LCD TV), press the POWER KEY repeatedly, slowly and patiently until your device (LCD TV) switched off. 8. Once your device has been switched off, immediately press (P+ or Ch+) and (Vol -) to lock in the code and the indicator should go out. 9. If fail, please try complete process from 1 till end.
Hope it works, since it works for me.
Jul 02, 2011 | Televison & Video
I have a Technika 32" LCD TV . when switching it
Check the connections??? Maybe get it replaced or repaired.
Jun 05, 2011 | Televison & Video
Technika flat screen: Will not switch on, the blue standby light just flashes
Technika flat 32 screen: Doesn't not switch on, the blue standby light just flashes.
Apr 14, 2010 | Televison & Video
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
WHEN TV ON STAND BY .GO TO OUT CHANNEL ON SWITSHES OFF
Either the power supply is shot or the set is in sleep mode. Can you press any other buttons beside channel. Or can you press numbers?
Aug 30, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Technika tt-16 universal remote control codes for a beko tv
Auto code search
Nov 10, 2008 | RCA Universal Remote Control
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
